RV.Net Open Roads Forum: General RVing Issues: Coleman Roadtrip grill (Update from Coleman)
 > Coleman Roadtrip grill (Update from Coleman)
General RVing Issues Related Tips
The Weekenders
Harvey, North Dakota
Posted: 08/18/08 02:10pm Link  |  Print  |  Notify Moderator
This spring, DW and I purchased a Coleman Roadtrip grill which has worked flawlessly this season. Then this Saturday evening, I was warming it up when I noticed flames coming from above the left side heat setting dial on the control panel 10 minutes after I fired it up. I quickly shut off the propane and put out the flames. The top left half of the plastic panel where the left flame control is melted away. It seems it has propane leaking out in the inner control when I later turned on the tank to check for a leak there.
Just wondering if this has happened to anyone else. Now I have to try to find the receipt from Menards so I can take it back.
* This post was edited 08/28/08 10:36am by The Weekenders *
Every meal is a feast, everyday is a parade and every paycheck is a fortune!
Rick & Sheila's RVing Album
Rick's Facebook
2004 Ford F350 6.0PSD
2008 Keystone Montana 3585SA
Park and Play
Wall Lake, IA
Posted: 08/18/08 02:17pm Link  |  Print  |  Notify Moderator
Yikes! We have not had this happen but we just got ours this spring as well.
Will have to keep an eye out!
The Adams Family :-)
Harley, Deb, Andrew-10, Tori-7
dhamblet
Olympia, WA
Posted: 08/18/08 02:19pm Link  |  Print  |  Notify Moderator
Been using ours for 2 years now with no problems
2005 Dutchmen 35SRV, Pergo, 5th Airborne, JT Strong Arm, Kodiak Disk Brakes, Backup camera
2006 Dodge CTD RAM QC 3500 LWB 4WD, Reese 16k, Airbags, Pacbrake, Britebox, 60g aux fuel tank
04 Harley Ultra, 05 CanAM 400MAX Quad
Spending my kids inheritance
Briteskys
Mesa, AZ
Posted: 08/18/08 02:54pm Link  |  Print  |  Notify Moderator
We have a Coleman Roadtrip too - so far no problems but its pretty new.
Thanks for the heads-up.
'02 Beaver Patriot Thunder
Jeep Grand Cherokee
Ron & Jane's Travels
Happy Camper2003
Liberty, S.C.
Good Sam RV Club
Posted: 08/18/08 03:47pm Link  |  Print  |  Notify Moderator
We've had ours for several seasons with no problems at all. Glad you caught it in time.
2003 GMC Sierra 2500HD 4X4 Ext.cab Duramax\Allison
Leer Cover
2007 Puma 31 DSBH
Me, DW, and 14 yr. DS
JOMO
Posted: 08/18/08 05:56pm Link  |  Print  |  Notify Moderator
We have used ours for 2 years and we haven't had any problems.
racefan1965
Redding, Ca.
Posted: 08/18/08 06:20pm Link  |  Print  |  Notify Moderator
Had my roadtrip grill for 5 years now. No probs but we've stopped using it too. Probably going to end up junking it just to get it out of the way. With just the 2 of us (kids are on their own now) we don't need a grill that big. Found a little one at walmart for under $20.00 with a latch to hold the lid down and folding legs.
Rick, Shirley, Lacy, Misty and 2 dogs(Shasta & Baylee)
2003 Ford 250 Superduty 4x4 LB 6.0 Diesel
1999 Dodge 2500 Quad Cab 4X4 gasser
1984 Alpenlite24 5er
1988 Coleman pup
2006 Champion C46540 RV plug ready genset
2009 Honeywell 2000i inverter genset
rrbowman
Lincoln, De
Good Sam RV Club
Posted: 08/18/08 06:47pm Link  |  Print  |  Notify Moderator
Whenever I have seen this happen it has been caused by a spider nest in the tube between the control valve and the burner where the louvers for adjusting the flame is located. This causes the propane to backfeed thru the louvers and catch fire. Spiders love propane.
The Weekenders
Posted: 08/19/08 04:19am Link  |  Print  |  Notify Moderator
The spider nest seems to make the most sense. I will have to try to get into the inside of it and try to fix it. Appreciate the help!!!!!
okiesquire
OK
Posted: 08/19/08 06:23am Link  |  Print  |  Notify Moderator
Never knew that about spiders & propanes. Good piece of info to remeber.
