RV.Net Open Roads Forum: Class C Motorhomes: BT Cruiser fresh water drain
 > BT Cruiser fresh water drain
arklady
Arkansas
Posted: 08/23/08 08:07pm Link  |  Print  |  Notify Moderator
I have a 2003 BT Cruiser, 23', 1 slide, 2 facing sofas. Fresh water tank is under passenger side sofa, and I cannot find the drain or water pump. Fresh water fill is just behind passenger door but no sign of drain anywhere on that side. Help, please!
Tonijim
MA
Posted: 08/25/08 02:42pm Link  |  Print  |  Notify Moderator
We have an '03 BT #5270 (28 footer, single slide, rear bed). Our water pump and drain valves are under the bed as is the fresh water tank. Gulfstream had no clue when we first de-winterized (after factory winterizing), so you may have the same trouble with them. If I had to guess, it would be either near the fresh water tank or at the rear. Have you followed the sound of the water pump to locate it?If you get under the chassis, you can probably see the outflow tube - otherwise, look for three (probably white topped 1/2" drain valves).
Good luck.
Jim
williegbro
Augusta GA
Posted: 08/31/08 07:03pm Link  |  Print  |  Notify Moderator
I have a 02 BT Cruiser, 22 ft. Facing the water tank, at the rear end feel around. It is a small, pinkie size lift up valve. Pull up on the T bar, and it will drain your tank. Also, on the rear outside storage space, driver side is TWO (2) of these valves to drain the lines. Pull up on the T bar. Water Pump is behind the rear of the fresh water tank. Lift the sofa, get on your knees, have someone turn on water with pump on, and you can hear the water pump. Good Luck
klhutch
Sububan Chicago
Posted: 09/01/08 07:25am Link  |  Print  |  Notify Moderator
We had a 2004 5230 which might be what Arklady has except for the model year. Underneath the passenger side sofa at the front of the water tank was a "box" made from plywood paneling. It was screwed to the floor with a single screw at the front and to the wall at the top rear with one or two screws. It was flexible enough that if you removed just the front screw you could lift it up and work under it. Underneath it was the water pump and the tank drain. Like Williebro says it is a little black fitting that is screwed to the floor and it has a Tee shaped handle on top. Just lift up the handle and your fresh water tank will drain, slowly, very, very slowly. Also as he said in the "this is not a storage compartment" compartment on the outside, driver's side, just forward of the access panel for the black/gray dump valves there are two more of these little valves. These valves drain the rest of the system.
Ken
Sharon.Lee
MIchigan
Posted: 09/01/08 01:49pm Link  |  Print  |  Notify Moderator
I have a 2006 BT Cruiser 30 ft. My fresh water tank, pump and "T" pull up lever to empty the fresh water in under the bed, behind the the tank. I bit of a pain getting to as is getting to the pump to winterize it.
Didn't know about the 2 extra "T" valves to drain the system. I shall look for them.
williegbro
Augusta GA
Posted: 09/07/08 08:19am Link  |  Print  |  Notify Moderator
Ken
williegbro
Augusta GA
Posted: 09/07/08 08:25am Link  |  Print  |  Notify Moderator
On my 02, 22 ft BT Cruiser. The water line drain valves, hot and cold, is in the rear driver side storage compartment. The compartment is just ahead of the dump valves door. Up against the outside wall. Just feel around, you can find them. Seems like Gulf Stream kind of stuck them anywhere. Hope this helps The fresh water tank valve really do drain the water SLOW.
Jpjlauer
ELKHART, IN
Posted: 09/12/08 11:55am Link  |  Print  |  Notify Moderator
I have a 2006 BTCruiser 5290.
Fresh water drain valve is inside the rear storage box on the drivers side.
The drains for the plumbing are in the bedroom under the middle bottom drawer. You have to remove the drawer to access the drains.
And while I'm at it, the hot water by-pass valve is behind the left bottom door next to the above drawer.
Jim Lauer
2006 BTCruiser
2007 CRV tow
