RV.Net Open Roads Forum: Class A Motorhomes: Generator Air vs. Dash Air
 > Generator Air vs. Dash Air
Page of 5
bugs53
Jacksonville, Fl
Posted: 08/27/08 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
I just finished an article by Bill Hazell (Lazy Days Mag) who has stated it is more economical (GAS MILAGE) to run your generator and roof air,while traveling, than to run your dash air.
He did not explain completely, so I am asking the forum for more info.
Keeping the math simple, Onan 7KW runs approximatley 1 gallon of fuel per hour. Driving 50 miles per hour would mean approx. 50 miles per gallon.
Let us say,
A Motor Home, using dash, air getting 8 miles per gallon, driven 50 miles uses 6.25 gallons of gas.
If by turning off dash air you could increase 1 mile per gallon, that now means you are using 5.55 gal per 50 miles. If there would be an increas in gas milage to 10 mpg then you seemingly use 5 gallons of gas for every 50 miles.
It appears on the surface that you have to get an extra 2 mpg to make it work, even considering normal wear and tear on Genny. What am I missing here?
How about some help here.
bugs53
08 Tiffen Allegro, Wrangler Shahara.2dr std, Us Gear Breaking
Mango 3speed cruisers
Cookie. Springer Spaniel
Economical Handyman
S. California
Posted: 08/27/08 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting information ! Not to make fun of your info.
But if it is HOT, fuel is the last thing I consider.
DeWayne & Judy
04 3810 Dutch Star
ISL 370
Frank's autoformer
01 Sahara Jeep-toad
F 374382
It is hard to kiss the lips at night, that has chewed your butt all day long!
Admiral
Lodi, Ohio
Posted: 08/27/08 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, EH comfort is foremost and I've had both on in 100 degree weather with passengers in the back.
As far as economy though, it's my opinion since your coach engine is already running, adding a little more resistance with the AC compressor wouldn't make as much difference as running a 10-20 hp engine in addition to it.
While we're on the subject, how far back in your coach is it still comfortable with just your dash air on in, say, 90 degree humid weather?
2004 Damon Daybreak 2960F V-10
05 Honda Element LX
Government is the great fiction, through which everybody endeavors to live at the expense of everybody else.
djevans
Tennessee
Posted: 08/27/08 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
Some good thinking going on here, but in the summer, we start the generator, both AC units and turn on the dash air as well. So we're probably not a good example.
But I will say this, I don't necessarily subscribe to the "writers" theory. Two diesel engines running or one diesel with an additional load.
Hmmm... I'm thinking there's some faulty computing going on. It might on some units with smaller gas generators and lighter AC units, BUT, our generator kicks in and goes to the highest speed if even one air conditioner comes on line.
Don . . . near 36.171N 086.784W, TN near here
WA4ZFN
2003 Fleetwood Revolution 40C - Saturn VUE
350hp Cummins ISC
- - - P i c t u r e s - - -
I'm confused, WAIT! Maybe I'm not!
rvten
Crossville,TN
Posted: 08/27/08 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
When doing the mountains and hills. Not using the engine air. Takes a little load off the engine.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008
Class C passed Class A owner
Pontiac G6
There is NO such Thing as a B+
trnfla
Tampa
Posted: 08/27/08 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
Also, the article points out that running the generator is a good way to excerise the generator like everyone is suppose to do monthly...
He also stated that this only applies to gas and diesel not LP generators.
Have a great time camping,
Terry
Please say a Prayer for my 12 month old Granddaughter VisitBella.com
Please visit my Photos and Blog NiceCamps.com
Now 2004 Winnie 31C
Had
2007 Zeppelin EZ190, 2007 Expy
1999 30' Dutchman Classic 5th wheel, 2005 F250
bingoldsby
Oregon State Parks - somewhere
Posted: 08/27/08 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
My opinion is that when it's hot enough to use the dash air, that's the time it shouldn't be used at all - for the protection of the engine and transmission. My dash air condenser covered up the entire opening of the engine's radiator - which also contains the cooling sections for the transmission and engine oils. Turning on the air conditioner and dragging up hills on a hot day seemed like a terrible thing to do to the engine and transmission by dumping more heat into it all.
Because I was having some engine heat problems (even after having the radiator recored), I decided to remove the dash air condenser completely. I now HAVE to use the generator and roof air when it's hot. It works great and I stay really comfortable.
I have no other reason to run the generator but in that situation, so it's good exercise while doing something productive and important. And the engine is much, much happier for opening up the front of the engine radiator completely.
Gas?? I don't know. Can't change any of it anyway.
Brian K7ZRZ
Campgrounding hosting - Oregon State Parks
1987 30' Holiday Rambler Class A
GL1800 Goldwing - Honda Scooter Mounted
2000 Silver Miata LS Toad
Serious WiFi
chiefcramer
USA Somewhere
Posted: 08/27/08 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
I think the figure of 1 gallon per hour to run the generator at full load is too high. Try checking the numbers at 1/2 gallon per hour which should be closer to actual usage.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2003 Odyssey
Two cats - Kitty & Casey (18 & 15 years old)
Fulltime since October 2007
Before you give someone a piece of your mind, make sure you can get by with what's left.
New rig - new Visited States Map
djevans
Tennessee
Posted: 08/27/08 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
chiefcramer . . .
Well ours is a Quiet Diesel and runs closer to 3/4 gallon of diesel per hour at the higher RPM. (moderate load) Some do run a bit more. With no load it's closer to .4 per hour. But even one AC unit on kicks the generator in to high speed.
I think he might have rounded up for "example" sake. I think if you cut his 1 to .75 he's still short.
Jim83Itasca
La Quinta Calif
Posted: 08/27/08 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Chief, My Onan 6500 running with both airs on consumes 1 GPH (measured) and with the PD9245 cranking also.....
Jim
Page of 5
