RV.Net Open Roads Forum: Tech Issues: Problem Filling Fresh Water Tank
 > Problem Filling Fresh Water Tank
JimC
Jackson, MO
Posted: 08/28/08 08:26am Link  |  Quote  |  Print  |  Notify Moderator
We have a Dutchmen Victory Lane Toyhauler and we are having problems getting the fresh water tank to take on a full load of water. When filling, it starts out good but it will quit taking water long before it is full. We have tried filling it slowly but even that doesn't seem to help. We bought a clear tube that goes into the fill opening from our RV dealer and it seemed to help at first but now that doesn't even seem to help. Has anyone else had this problem or does anyone have an idea what is wrong? We have friends with the same exact toyhauler and they don't have a problem when filling.
Thanks,
JimC
Rollincool
Always Rollin
Posted: 08/28/08 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Maybe a critter (bug) got into the vent pipe? Sounds like its not venting properly.
2008 Chevy Silverado 4x4 3500 RC/LB 6.0
2007 Chevy GS Conquest Super C 6340DK
2007 Chevy HHR Toad 2LT 2.4
1990 Chevy G20 Cargo Van 305
1967 Chevy Camaro Pro Street 468/650hp BBC
My 70's Show - Tom Kent Radio Network - KLTH - K•HiTS 106.7
McIrish
WC IL
Posted: 08/28/08 08:56am Link  |  Quote  |  Print  |  Notify Moderator
I had an older Dutchmen with the same problem. I bought a longer clear hose that was 4 to 5 feet long and inserted it into the fill hose all the way. We could then get our tank full.
2008 Silverado Z71 crew cab
2009 Sunset Creek 267RL
Equal-i-zer
hershey
Albuquerque,(fulltime) NM, USA
Posted: 08/28/08 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Suggest that you get a 1/4" plastic hose and stick it into the filler spout about 18 to 24" then fill, not through the 1/4" hose but using the 1/4" hose as a vent. Sounds like the tank isn't venting.
hershey - albuquerque, nm
Someday Finally Got Here
NASCAR 20 - - 99
Jerrybo66
AZ
Posted: 08/28/08 11:08am Link  |  Quote  |  Print  |  Notify Moderator
I had the problem also. To start with I was filling too fast then I found that the hose that connected the two tanks had a sag in it. I fastened it straight, fill more slowly and end up with two full tanks. I hope your fix is this easy.
Support the Country you live in or live in the Country you support
2003 Sierra SP 26'Toy Hauler
1997 F-350, PSD, 4X4, red Crew Cab, long bed.
2007 Arctic Cat Prowler, Arctic Cat 500
BFL13
Victoria, BC
Posted: 08/28/08 11:16am Link  |  Quote  |  Print  |  Notify Moderator
With ours, the hole in the inside wall was not in line with the outside hole for the filler and vent hoses. The clear vent hose was pinched off where it was jammed against the inside wall hole edge by the filler hose. I had to cut a bigger hole in the inside wall to give the vent hose some room. Problem solved.
beemerphile1
NE Ohio
Posted: 08/28/08 11:34am Link  |  Quote  |  Print  |  Notify Moderator
Long version; I have two tanks that are linked together. The first tank would fill as normal but the water was slow going into the second tank through the link. I checked both vents and discovered that the vent for the second tank was plugged. Probably some bug thought it looked like home! I blew out the line and all is good now.
Short version; you probably have a plugged vent line. If air cannot get out, water cannot get in.
Tim
"Okay, I admit it, the only thing I'm really good at is being me."
Support the "No Child Left Inside Act"
2006 Weekend Warrior FK1900
1998 Ford E150 4.6L
1996 BMW R1100GS
2005 Trek Madone 9spd.
1995 Burley tandem
JimC
Jackson, MO
Posted: 08/28/08 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks to everyone for their tips...we will see if one of your suggestions will work for us.
dbates
Marion, Indiana
Posted: 08/28/08 10:24pm Link  |  Quote  |  Print  |  Notify Moderator
I had the same problem & found that the manufacturer had tightened a nylon tie too tight around the air vent tube & collapsed it. I replaced that section of tubing with copper pipe and now I don't have a problem.
Dave
Plus New Brunswick, Prince Edward Island & Nova Scotia
