RV.Net Open Roads Forum: Roads and Routes: Durango to Denver
Search only in Roads and Routes
Open Roads Forum  >  Roads and Routes
 > Durango to Denver
JohnInAz
Arizona
Posted: 08/29/08 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
S&T maps the route using US 160 to US 285. Is this route ok with a 35 foot motorhome pullng a toad?
Thanks
2007 Jayco Seneca 34SS
2006 Jeep Grand Cherokee toad
cm
Dillon, CO USA
Posted: 08/29/08 10:35pm Link  |  Quote  |  Print  |  Notify Moderator
If you like mostly two lane mountain roads with a couple of high mountain passes. A lot of good scenery.
NGRRFan
Colo. Spgs., CO
Posted: 08/29/08 10:38pm Link  |  Quote  |  Print  |  Notify Moderator
Let's see...... take 160 east through Pagosa Springs, then up and over Wolf Creek Pass, and down to Monte Vista and pickup Hwy 285 north. The is an easy drive towards Poncha Pass, and Poncha Pass isn't all that bad.
Down the north side of the pass to Poncha Springs and then north to Johnson Village. This section of road is rolling hills.
From Johnson Village the highway turns east and climbs to the top of Trout Creek Pass. This section winds and curves around as it follows the canyon, it isn't all that bad, just a bit frustrating as there are few places for people to pass you.
After cresting Trout Creek Pass you drop down into the western edge of South Park. Here the highway is "flat" but still following along the foothills as you head into Fairplay.
North of Fairplay you climb Red Hill Pass, more like a bump in the road and continue on to Jefferson where you start to climb Kenosha Pass. The climb isn't bad, but the north side is all downhill to Grant. The highway is very beautiful along here.
From Grant you follow the river for a while, still relatively flat, until you get to Indian Hills. From there to C-470 it is all downhill.
You shouldn't have any problems at all with your rig.
Rich,and Tobi (the rescued dog)
Prowler 5ver, 84 Ford F250
KCOCOLOR78 Weather
Colo. Spgs. CO
boje
Glenrock, Wyoming
Posted: 08/30/08 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Wolf Creek is quite the climb fyi.
sparker1
St Petersburg, Fl, USA
Posted: 08/30/08 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Any other route is either tougher or at least 100 miles farther.
Stan
2002 Monaco Windsor DP
2003 Honda Pilot
Travel photos at Photo Gallery
Lou3NLyn1
Posted: 08/30/08 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
That is the way we go when we head for home!
Lou
Lou & Lyn
2007 Fleetwood Southwind 37C - Satin Steel
2007 Saturn VUE AWD
Busskipper
Arnold,Md
Posted: 08/30/08 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
Beautiful drive -- but you might look at going thru Leadville on Rt24 to I-70.
Most of the roads are fine in a large coach and toad with the scenery being well worth the drives.
BOL,
Busskipper
Maryland/Colorado
Travel Supreme 42DS04
MDX-FMCA--M&G Brake
States traveled in this Coach
cm
Dillon, CO USA
Posted: 08/31/08 09:22am Link  |  Quote  |  Print  |  Notify Moderator
"Beautiful drive -- but you might look at going thru Leadville on Rt24 to I-70."
Going through Leadville is going to add more climbing. Leadville is at about 10,000 ft elevation and Buena Vista is about 7,900 ft. But then you have to climb Tennessee Pass which is not bad but you go down to Minturn and through Vail which is about 8,150 ft and then have to climb Vail Pass, 10,666 ft, from the west which is the harder climb.
If you want to go to Leadville, which is very interesting, a lot of mining history, a easier route is go from Leadville on Highway 91 over Freemont Pass, 11,318 ft, and get on I-70 at Copper Mountain for the drive to Denver. But I-70 adds the climb from Silverthorne to the Eisenhower/Johnson Memorial tunnels, 11,158 ft, which is a long and high climb. The only advantage to I-70 is that it is 4 lanes.
Going Highway 91, Freemont Pass, you miss Vail but to be honest Vail is not RV friendly. And while Vail is a great ski area the views in Vail are not as good as Leadville, etc. Unless you like to see a lot of very expensive houses, and condos.
The most direct route and probably the easiest is Highway 285. From Buena Vista through Fairplay and South Park has great mountain views. If there is time stop at Fairplay and see South Park City. They have created a mining era town using real buildings that have been moved from old mining camps and towns in that region. The climb over Kenosha Pass, 10,001 ft is not bad.
rsherrie
Littleton,CO
Posted: 08/31/08 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks
I travel that way all the time with a double tow and find it easier than the Interstate. Enjoy!!
JohnInAz
Arizona
Posted: 08/31/08 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, thanks for all the information. It sounds like it could be quite a ride!
 > Durango to Denver
