RV.Net Open Roads Forum: Class C Motorhomes: Flashing refrigerator light
 > Flashing refrigerator light
timwright
New York
Posted: 09/05/08 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Jayco 24 with a Norcold refrigerator.
On a recent trip, when I put the switch on gas, the light began flashing ("GAS check if flashing"). The fridge had warmed up and was obviously not working. I had no shore power at the time.
However, when I put the switch on Auto, it started working perfectly.
Any ideas on why this happened?
Thanks. Tim
Chuck&Gail
In the Colorado Mountains
Posted: 09/05/08 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Lite flashes when burner does not lite. Ours quits trying after a certain number of tries, but lite keeps flashing. When you went to auto, it retried and lit.
Usually happens when propane supply was stopped, even just enough for air to enter lines.
My opinion, worth what it cost.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
evanvalk
Tampa, Fl.
Posted: 09/09/08 08:21am Link  |  Quote  |  Print  |  Notify Moderator
When you have it set to elec.it will only work on elec.when you set it to auto(always)it will run on elec when pluged in to shore power,but when you unplug from shore power it will automaticly switch to gas. If the gas is off it will blink to let you know to turn on the gas.leave it on auto and you wont have any problems.just make sure the gas is on before you unplug it. Happy camping. Ed.
ED. & ROSE.
THOR FOUR WINDS 31P.CLASS C 31FT.
FORD E 450 V-10 6.8 GAS.
TAMPA, FL.
Westronics
Redmond, WA
Posted: 09/09/08 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
I have had this happen to me before, too (when switching from electric to gas on "auto").
I have learned that one must check the fridge after un-plugging to be sure it switches properly. If not, a simple recycling of the power ("off" and then "on") usually solves it in only one try.
If I do not check it, sometimes (not often) it will fail to start up properly on gas. Maybe a little air got in teh line or something, but it's a pain for sure if I forget to check it and its off long enough to warm up (that's a pretty long time).
2002 Jayco Greyhawk 24SS, Cameras (RVCams), ScanGauge II/Blendmount, 300W Inverter, Airtabs,12' Portabote w/sail, Be kind to septic systems.
Ford motorhome customer service: 1-800-444-3311.
MikeMike
St.Petersburg,Florida
Posted: 09/10/08 12:28am Link  |  Quote  |  Print  |  Notify Moderator
I ran into this same problem after storage-its caused by your LP gas having to displace any air thats in the lines-now as a fulltimer,with alot of use,it switches from electric to gas instantly.You may have to keep moving the switch to relight it 6 or 8 times before it fires-its like a auto coil that fires a spark-you can actually hear it -I have cleaned and checked all connections to the fridge (everyone should do it)and sprayed all gas connections with soapy water from the tank to everything connected-just to be safe.
dmatt
Ventura County, CA
Posted: 09/10/08 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with above. You probably have to clear the air out of the line. Need to get the flow of gas running to clear the line
2007 Four Winds Dutchmen 29R-Ford E-450 V-10 towing a 2008 Toyota Matrix XR
2007 Toyota 4Runner(V-8) towing a 2006 Reinell 220LSE, 5.0L, 280hp GXI
Our camping photos
under the stars
