Wherever I happen to park
For those who say "you don't need to buy the more expensive unit with analog pass through.........."
Right, just E-mail me and I'll send you my JPG of how to do it
hohenwald48
Hohenwald, TN
What would be the reason to have analog pass through after Feb 2009?
2001 Monaco Knight
2004 Dutchmen Dorado
1999 Jeep Wrangler
100% Solar Powered Home
When seconds count, the police are only minutes away.
MRUSA
Boca Raton, FL
"What would be the reason to have analog pass through after Feb 2009?"
Some low power stations will not be converting to digital in 2009. Also, you can use analog to view the signal from VCR's and some other older equipment.
Marc, Boca Raton FL
2003 Beaver Monterey 40' triple slide
Blue Ox TruCenter
Acura MDX toad
Unified Tow Brake
Pressure Pro Tire Monitor
Garmin 2610 GPS
Datastorm D3/7000
Sirius Radio
Tivo on board
I will give you an even better reason for analog passthrough in March of 2009 (or later) OVER THE AIR is only one source of video. You also have VCR, DVD (To a modulator) Video Cameras and other sources... if you put the converter in the line to the television AFTER THE SWITCH (necessarly if you want to watch different shows on different tv's) then analog pass through is a must for these alternative sources.
e&emc
Davidson, NC 28036
I have a tv, vcr and amplifier and batwing antenna. I have never gotten real good reception. I purchased the Zenith converter and put it between the antenna and amplifier and get 22 stations perfectly now. This is without rotating the antenna at all. Just for kicks I lowered the antenna and the stations still come in just as clear. My question is do I have the converter where it should be? The only instructions in the box where to hook the antenna to the box and the box to the tv. As most of you know changing the hookups is no easy task on an older winnebago.
rvten
Crossville,TN
Some of us have figured out how to set up the converter box so you can have anolog and digital feed with no wire swaping. It is not hard. Bat wing antenna is UHF/VHF and should work with no problem.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008
Class C passed Class A owner
Pontiac G6
There is NO such Thing as a B+
talonguy
Schertz, TX
For those of you really interested in this, Wilmington, NC, went all digital just recently (Sept. 8) as an early test of the country-wide February switchover. Many people are not happy and at least HALF of current OTA viewers are no longer able to receive one or more local major network affiliates they were able to receive before. You can read about it here.
It is a fact that the digital cliff (cliff effect) will reduce the distance a digital signal is receivable on a 1 for 1 transmitted power comparison (digital vs. analog). Also the talk that MOST stations are transmitting their digital signals at a reduced power level may or may not be true. They have the option (currently) to broadcast at a reduced power level, however many are not. They only way to know who is and who is not is to call the individual station.
Abner055
Urbana, MD
I always get better reception on the digital channels. IF I cannot get digital, analog doesn't come in good enough to watch or not at all. My televison has a built in digital tuner.
I keep a compass in the RV and use it with my GPS to determine where the closet town is at in to relation to me and aim the antenna towards town. I almost always get a few digital channels. If I can't get digital, the analogs are not worth watching and I just watch something that I had previously recorded on my DVR. I normally keep about 220 hours worth of programming on my DVR.
Wife, 2 MinPins(Penny & Cindy) & Me
2008 Gulf Stream StreamLite 22FB
2008 Nissan Armada LE 4X4 V8 w/Tow Package
Blue OX SwayPro WD Hitch - Prodigy Brake Controller
Honda EU200i Generator - PI PT30C Smart Surge Protection
2005 Honda Shadow 1100 Motorcycle
kmb1966
Houston
Hey, maybe try this: Make yourself a coathanger type bow-tie antenna, connect it to the CABLE IN where you would normally connect cable from the pedestal, connect the digital converter box to the "cable" line inside the MH instead of the antenna line. Place your coathanger antenna outside somewhere wherever you are parked. The old coathanger bow-tie type antenna's pick up the digital signal much better than our batwings!. Try it.
Countrybiker
Amite, Louisiana
The way I understand it, is that if your TV isn't digital, then you need to get a converter. Now this may be a dumb question, but is there a way to tell if your TV has a digital tuner?
Rick & Dee
2006 National Seabreeze
2004 FLHTC as our Toad
