RV.Net Open Roads Forum: Class A Motorhomes: help 3126 turbo troubles
 > help 3126 turbo troubles
urmine351
fort smith, arkansas
Good Sam RV Club
Posted: 09/18/08 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
today, traveling up i-81 and i-88, bad loss of power, turbo only will get 8-10 psi changed fuel filters, did not help. what do i need to do and anyone know of a good shop near franklin,ny? i am from arkansas traveling to vermont.
1996 Safari Serengity, 3126 Cat,Allison 6 speed, 38' DPNS, 2005 Honda Element,vip tow brake. doran tire, Magellan750Nav,
and 1 good looking wife, and missy and Alex(died 11-03-06) and AJ, born 09-06-06 my carins. and Max, teacup yorkie
FMCA # F374886
Deen
Vancouver, WA
Posted: 09/18/08 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Exhaust brake stuck
Bad connection to the CAC?
Bad connection from CAC to engine?
CAC has a hole in it?
Bad turbo
Check in that order
wallynm
Los Alamos NM
Posted: 09/18/08 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
Replace the air filter
DONATE THAT OLD CELL PHONE TO SUPPORT SOLDIERS click here
Have a Cat Engine Yahoo Group or Cat RV Club Web Page
Have a Freightliner Yahoo Group or FCOC Web Page
2002 DSDP 3567 PUSHED BY KITTY KAT
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
as197
NorCal
Posted: 09/18/08 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
What Deen said...
If you had a sudden loss of boost you have a leak somewhere. Changing the air filter is not gonna fix it either. Check all the boost hoses and their connections.
noRVtoheaven
So. California
Posted: 09/18/08 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
This much loss of boost usually indicates a serious leeak in the boost system or a crack in the Charge Air Cooler. Do not waste money allowing some mechanic to run up dignostic time. Go to a CAT Dealer with a Dynomometer and get an accurate diagnosis. A CAG is expensive. You need an expert dignosis.
VERITAS PRAEVALEBIT
bkd148
Spanaway, WA.
Posted: 09/18/08 09:59pm Link  |  Quote  |  Print  |  Notify Moderator
Check all the clamps and hose connection for the air to air exchanger. Sometimes the clamps burst open or the hoses slip off or the hoses split open.
Marty
2002 Beaver Patriot Thunder
Cat C-12 455hp. 6spd. Allison
2002 Jeep Wrangler Sahara
Bruce Brown
Northern NY
Posted: 09/18/08 10:41pm Link  |  Quote  |  Print  |  Notify Moderator
I can highly recommed Tracy Road Equipment. They have locations fairly close to you in both Syracuse and Albany.
As for the trouble, do you always let the turbo cool for a few minutes before shutting it down? Thats a big deal and far too many people don't do it.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
box710
albany ny
Posted: 09/19/08 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
If you hear a hissing sound when accelerating you have a leak in one of the turbo channels. could be just a loose clamp good luck.
pfunk
Shelby Township, MI
Posted: 09/19/08 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
If it was coked up, it wouldnt be making any boost in a short time those bearings fry quick.
Check the ussual suspects for leaks and visuals,,, hate to say it, but it may help to have the cover up and listen for a brave soul (what I would do)
2000 Holiday Rambler Endeavor
300 Cat 6spd Ally
urmine351
Good Sam RV Club
Posted: 02/03/09 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
you have a spit hose...one of the big ones
