RV.Net Open Roads Forum: Tech Issues: 2007-2008 refrigerators better than older ones?
 > 2007-2008 refrigerators better than older ones?
ezridn
Houston
Posted: 09/20/08 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
i have a lance 02 the refer does not stay on gas when on the road.. have tryed all the tricks. also if i put my worm six pac in it it warms up the refer foe a day jest wondering if they got any better over the years thanks
2001 lance 1130 ..2001 ford350
Learjet
Louisiana
Posted: 09/20/08 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
yes, never had those problems
2006 Nissan Titan CC with tow package
2006 KZ Frontier 2303P-F
Equal-i-zer
Prodigy brake controller
Yamaha EF2600c Tri-Fuel Gen.
lhuff
Marietta, GA USA
Posted: 09/20/08 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2000 camper with a two door Dometic refrigerator and it's never had that problem either. I'm not sure it's a model problem.
Wherever I happen to park
Posted: 09/20/08 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
Well... I don't have either of those issues with my 2005 Dometic.
However I also don't put a six pack in it, ever
mike4947
N. Syracuse, NY
Posted: 09/20/08 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
The design is basically the same since they changed it in the mid 1990's to reduce the incidence of crystallization from running off level.
We've found 50% of RV absorption fridges are mis installed. Either they are vented wrong, have a bad or missing baffle, or the insulation has been damaged or is missing.
Check here for a service manual for your make and model and review This for the proper venting and baffling.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
Want to sell some of your gear? -
Free Classified Listings on RV.Net
They say you learn by your mistakes, in that case I must be a genius.
tropical36
Southwest Florida_USA
Posted: 09/20/08 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have that problem with my 98 or did I have it with my 87. Only difference is that my present coach is automatic and 120vac is default, whereas the older one had to changed from elect. to gas manually.
"We are often so caught up in our destination that we forget to appreciate the journey."
1998 36ft. National Tropi-Cal, with a tag axle and one slide, on a 1997 P32 Chevy chassis....7.4 Vortec Engine
