RV.Net Open Roads Forum: Truck Campers: camper cover
 > camper cover
RoadRunner65
CA USA
Posted: 09/20/08 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone use a camper cover in winter?
jefe 4x4
Nevada City, CA
Posted: 09/20/08 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
No.
I do use a heavy gage cotton duck tarp. It's about 16'x20'and weighs about 40 lbs. I bungee down the grommets to keep it from flapping in the breeze. It covers the top and down to below the windows. So far so good. Since it's breathable, it doesn't collect water underneath, at least not for long, and doesn't mar the surface. It does load up feet of snow just fine. More than a couple feet deep and I use my 'roof rake' to pull most of it off.
In the past I've used one of those pale green, breathable truck covers, just on the truck. The 100 mph Santa Anna winds made short work of that thing. I got most of one season out of it.
regards, as always, jefe
'01.5 Dodge 3/4T, CTD, HO, Qcab, SB, 4x4, 6spd, D60, D80+Pwr Loc,
camper&tow pkg,Titan V, 285/75R-16 frnt, 33/14.5 Nitto super singles rr,
Rancho 9K's, Warn M15K winch. tows Jeep CJ8 rock crawler on 14' trailer
'98 Lance Squire Lite 165s, 8' 6" X Cab
SoCalDesertRider
SanDiego, CA, USA
Posted: 09/20/08 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
I used a 16x20 heavy silver/brown poly tarp from Lowe's. The ones from Harbor Freight are cheaper, but don't last nearly as long. The Lowe's tarps are better.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
Dick_B
Palos Heights, IL USA
Posted: 09/21/08 07:04am Link  |  Quote  |  Print  |  Notify Moderator
Search this Forum for RV cover. It doesn't make any difference in the type of rig there are pros and cons for covering.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
trails2004
Wyoming
Posted: 09/21/08 07:14am Link  |  Quote  |  Print  |  Notify Moderator
Lots of information on covers- use the search function. Last fall I purchased a Calmark cover (Click Here)
If you value your investment you should cover it. The cover must breath or you risk moisture being trapped and that is not good- so scrap the blue tarp.
2002 Dodge Ram 2500 SLT 4x4-AFE Cold Air,4"Exhaust,Toyos,Ranchos,Dual Air III- Firestones 2004 Hallmark Cuchara XL 9.5 w/Carbon Fiber Roof, WFCO 9845,Xantrex XBM,Honda 2000,1997 Grumman GV19TC- Crew Wifey,(Odin,Bridger & Sam,Wirehairs)
markacruciani
Minnesota
Posted: 09/22/08 10:12pm Link  |  Quote  |  Print  |  Notify Moderator
Calmark. $500-600 but you'll buy it once. Also, cheap plastic-based
tarps in the wind can do some pretty amazing damage to the surface below
it given enough hours.
RoadRunner65
CA USA
Posted: 09/23/08 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Thanks!!
 > camper cover
