RV.Net Open Roads Forum: Let us see pictures of your modifications
 > Let us see pictures of your modifications
dav5942
Stuart, FL
Posted: 09/21/08 07:34am Link  |  Quote  |  Print  |  Notify Moderator
Click below under Newmar Mid Engine(most done by us)-
2007 Newmar 42' Mid Engine w/Fatboy,ATVs-in Garage,lifted Jeep(s) in tow, Hog Valley Florida(a diamond in the rough),'09 Alaska again!
2007 Tour Alaska Fishing '08 Tour Grandchildren Newmar Mid Engine
virginiarebel
Auburndale, Fl.
Posted: 09/21/08 07:35am Link  |  Quote  |  Print  |  Notify Moderator
Bruce Brown wrote:
I finally fixed them...
Here is our
Slide End Paint
and
Outside Entertainment Center
both done in our garage.
Very very nice modifications. Very neatly done. Looks professional.
2002 36' Monaco La Palma DBD Ford V-10
2 slides, 2 sinks, 2 potties
Toad - 2001 Saturn SL2 w/Sunroof/CD/Cassette
Falcon All Terrain Hitch & US Gear Toad Brake
Ivylog
Blairsville, Ga. USA
Posted: 09/21/08 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Removed sofa and replaced with office area for two puter.
04 Monaco Dynasty 42' quad slide
DP01
Southern Ontario
Posted: 09/21/08 08:44am Link  |  Quote  |  Print  |  Notify Moderator
Mounting a Garmin 7200 without drilling holes. Plywood covered with vinyl (temporally) fits into the upper drawer. The GPS is easily visible from either side.
Dennis
* This post was last edited 09/21/08 09:07am by DP01 *   View edit history
Daveinet
il
Posted: 09/21/08 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
Cherry rear window frame and window treatment.
Modified lower ball joint mount to accept Hummer H1 ball joint.
Changed upper shock mount to accommodate Koni FSD
And last but not least, the 502 with multiport fuel injection.
Also not shown was to bore out my bellcranks and install tapered roller bearings. Installed Koni FSD on rear, and moved the upper shock mount so that the shocks would be more vertical to accommodate the damping rate of the Konis.
Dave
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Thorley's & Magnaflows,
Howell/Edelbrock MPFI, Koni FSD,
Class A built for gear heads
My Revcon Website
Revconeers Forum
XP activation frustration
novatz
Cross Hill, SC
Posted: 09/21/08 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
No pictures but:
1 - added under cabinet slides (2) under the cook top. Same kind of slides I added throughout the kitchen at home.
2 - added a toe switch to the vacuum cleaner. The system previously had you shove the hose in for a connection. Too many problems and no shut off. Toe switch - hose in gently, on/off, no yanking to pull out.
'08 40' Monaco Diplomat Superslide
'08 Chevy Silverado with Rampage loader
'05 Gold Wing
'41 Spouse
'05 Cat
trailmeisterjoe
bothell, wa
Posted: 09/21/08 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
Anml_341 wrote:
Good idea this post!
Sorry, I have not figured out how to post pictures but our modifications include:
a) Checked cupboards and if upper portion was not used, added a shelf.
b) Checked closets and if upper or lower portion not used, added another shelf.
c) Kitchen table - bench seats with drawers - storage space behind drawers easily accessible if bench lid is removable.
d) Added a storage box to outside at rear bumper for storage of flamable items such as extra propane, outboard motor gas, etc.
e) Removed carpet from living room area and installed vinyl laminate oak flooring.
f) rewired a/c circuit to provide additional plug in for a heater that is only used in cool weather when a/c is not used.
g) Added "hypervent" under the mattress to prevent mildew from forming over the storage area.
h) replaced some light fixtures to give better lighting for reading.
i) Added VCR holders under a overhead cupboard to hold satellite tv and internet receivers with two-sided tape to hold receivers in place while travelling.
j) Added plastic boxes to area under the sofa to store office type items and papers.
k) Added expandable grating to electric step to prevent slipping rather than using fabric type step covers that hold moisture and increase rusting of steps.
l) Added brackets to outside to carry our Porta-bote (12 foot foldup boat) that in the travel mode is 4 inches thick.
Anyone interested, I can email pictures. (email: frankspence@hughes.net)
Frank, i would DEFINITELY rethink"D" as it would be a disaster in even a slight rearend collision.
Joe
'99 rexhall rexair with 2 slides 32 ft
Alphamonk
North Carolina
Posted: 09/22/08 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
Bruce Brown wrote:
Here is our
That is one fine looking installation on the intertainment center.
tahiti16
Camarillo, CA
Posted: 09/22/08 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Really sharp looking rig Dave and the mods were mostly so common sense why don't the manufacturer's do this to start with?
Ray, Cheryl, Cory & of course Miss Molly the four-legged child
2006 Dolphin 36' F53 V10 6 speed auto 2 slides 7.5 KW genset
OzarkPreacher
S.W.Mo. God's Country
Posted: 09/22/08 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
Nothing major yet. We recovered and refinished the dining chairs
refinished the table top
replaced the love seat with new home size unit and club chair with a recliner that matches new couch.
recovered the window treatments and colored the light shade and added some gold trim to it.
On the list for this winter,
1. refinish cabinets
2. remove carpet and replace with laminate.
3. If finances allow have captains seats recovered with leath
