RV.Net Open Roads Forum: Class A Motorhomes: Splindide Washer/Dryer - 2000 series
 > Splindide Washer/Dryer - 2000 series
sepisllib
Cresco, Iowa
Posted: 09/21/08 05:15am Link  |  Quote  |  Print  |  Notify Moderator
Ok!
In confess that although I do have the booklet on this combination, I have only "skimed" through it.
The unit washes nicely and does a good job, however drying is different story.
I checked the outside "vent" and it has a little flapper on it - the flapper is free and there is no lint in or around it to hamper it's operation.
I do not see any place to clean out the lint inside the unit - so my question may be dumb - but:
How do you clean out the lent on this unit without actually removing the entire unit from it's resting place in the cubbyhole?
God Bless
Bill
Bill W. Trammell
Wife - Judy
2001 Monaco Dynasty Chancellor
2008 Malibu 2LT toad
desholar
Mississippi
Posted: 09/21/08 05:45am Link  |  Quote  |  Print  |  Notify Moderator
had the same problem bought the coach used and could not make the dryer work....talked with splindora and they helped me trouble shoot...even though the dryer vent appeared to be clean when i looked from the outside i still had to pull the unit out clean the vent from the bottom of the machine up and then replace the silver line from the dryer to the side of the mh. it comes out pertty easy but watch ur fingers...lol...i still have one blue finger nail...no way to do it other than pulling the machine.now it drys too hot so wife uses the low heat setting
2002 Winnebago Cheiftian
2004 F-150 Crew Cab Toad
2 Cats
1 DW
LIVE WELL...LOVE MUCH....LAUGH OFTEN
Gary Franks
Pacific Northwest
Posted: 09/21/08 05:50am Link  |  Quote  |  Print  |  Notify Moderator
You could try one of those "As Seen On TV" products that has a chimney sweep type wand for cleaning lint behind a washer/dryer. The kit also includes a vacuum attachment. However, I found that none of them are long enough to reach through the vent hose from the outside.
I ended up pulling my Splendide out and replacing the hose. The lint was so caked in there it was just easier to replace it.
Also, if this is your first experience with the Splendide, be sure that you don't have too much in the dryer. Mine works fine as long as I don't try to dry more than one sheet at a time; three T-shirts at a time; one bath towel and one two hand towels at a time; (you get the idea).
* This post was edited 09/21/08 06:01am by Gary Franks *
'05 Fleetwood Bounder Diesel 39Z | Datastorm F2 Satellite Internet | Toad1: '03 Lincoln Town Car | Toad2: '08 Jeep Wrangler Sahara Unlimited 4WD
Anml_341
Ontario, Canada
Posted: 09/21/08 06:50am Link  |  Quote  |  Print  |  Notify Moderator
There is a saying that goes something like this: "When all else fails, read the instructions" so I have been told...many times...
Frank Spence
Ontario Canada
Member: Explorer-RV Club (Canada)
Member: FMCA #F275853
We invite you to check out our websites:
http://flspence.blogspot.com/
http://rvworkshops.blogspot.com/
http://fourseasonsrving.blogspot.com/
hershey
Albuquerque,(fulltime) NM, USA
Posted: 09/21/08 07:22am Link  |  Quote  |  Print  |  Notify Moderator
My water pump has leaked twice on mine, so in the process of replacing the seal on it I had to remove the back of a closet to get to the rear of the washer. In doing so, I had to remove the vent hose to the washer/dryer. Its held in place with sheet metal screws (on mine) and of course they attract the lint and continue to allow it to build until the vent hose is plugged. I've replaced the sheet metal screws and just used good ole duct tape and it continues to breath properly.
hershey - albuquerque, nm
Someday Finally Got Here
NASCAR 20 - - 99
cquinn5
Titusville FL US
Posted: 09/21/08 08:21am Link  |  Quote  |  Print  |  Notify Moderator
Bill,
Check to see if the unit has a lint filter. Ours is also a 2000 Splendide and has a lint filter on the back of the unit just prior to where the vent hose hooks into the machine. Our lint filter is accessed by lifting a hinged flap on the panel that is on top of the washer and pulling the lint filter straignt up.
Cliff
Cliff & Karen Quinn
The Great Outdoors
bullydogs1
New Jersey
Posted: 09/21/08 08:43am Link  |  Quote  |  Print  |  Notify Moderator
Not to add fuel to the fire, but the specs says it can wash 15 lbs of clothes but dry only 11....So there's your proof it can wash more than it can dry. Also drying is electric running on 110 AC so the drying power can only be as half of a residential one that runs on electric.
Stuart and Stella Denning
2009 Holiday Rambler Endeavor 41SKQ
Our 4 Bulldogs (Summer, Sully, Sierra and Great-Grandma Demi)
2007 Saturn Vue (TOAD)
Diesel is provided by your safely trained drivers, as pictured below
HobbyHauler
South of Nashville, TN
Posted: 09/21/08 09:00am Link  |  Quote  |  Print  |  Notify Moderator
Mine has a lint filter on the front bottom right corner. You clean it while the machine is in the spin cycle. While listed as self cleaning, the manual gives the procedure for cleaning the "self-cleaning" filter.
Les Stallings
2002 Monaco Dynasty Jack 38, ISL 400, TAG
Toad: 2003 Saturn LW300
John S.
Northern Virginia
Posted: 09/21/08 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Also take out the clothes before it starts to dry and shake them out so they fluff a bit and are not stuck together from the spin cycle.
John
2001 42' Foretravel U320
2007 Bornfree 24 Painted
2001 Jeep Wrangler
2007 Burgman 650 Executive
Susie and Dolly (Cavalier King Charles Spaniels)
Dolly now in our hearts and thoughts 8-27-05
Doodle a Black and Tan Cavalier
Lolly a Ruby Cavalier
tgt
Oregon
Posted: 09/21/08 09:55am Link  |  Quote  |  Print  |  Notify Moderator
After you figure out your lint filter problem... drying just a few items is better and those dryer balls really help too. Do not use dryer sheets, as they are small enough to be sucked into the lint filter. Use a little liquid fabric softener, diluted with water. Your clothes won't wrinkle (so much) this way and if you use a liquid fabric softener, so many of your clothes will be even better if you put them on a hanger and dry them in the shower. Clothes will last much longer if not dried in the dryer too. (my 2 cents)
tgt
2004 Country Coach Intrigue
2007 Honda CRV
