RV.Net Open Roads Forum: Tech Issues: Water heater adjustment
 > Water heater adjustment
chi6488
florida
Posted: 09/21/08 08:47am Link  |  Quote  |  Print  |  Notify Moderator
I have a 10 gallon atwood wh. First trip out my wife and I both thought it was rather too hot. We have two kids so we are concerned. Any suggestions how to turn it down??
2009 Jayco Eagle 324BHDS
2008 F250 King Ranch 4wd
2005 GLacier Bay 2670 Cat
TennesseeBob
NW Tennessee
Posted: 09/21/08 08:58am Link  |  Quote  |  Print  |  Notify Moderator
You can install a adjustable thermostat found at your local dealer
2005 3500 Dodge QC Dually CTD
2004 Newmar American Star 32RLKS
Paris,TN
Hurricaner
Hurricane Utah
Posted: 09/21/08 09:17am Link  |  Quote  |  Print  |  Notify Moderator
Yep.
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
donn0128
Pronounced Ore-gun
Posted: 09/21/08 09:32am Link  |  Quote  |  Print  |  Notify Moderator
Newer water heaters do NOT have an adjustable thermostat. Found this out the hard way on the last TT. Same complaint, Dealers was great and installed a new thermostat. Guess what? It was hotter than the old one!
Donn
Dusty R
Charlotte Michigan 48813
Posted: 09/21/08 09:51am Link  |  Quote  |  Print  |  Notify Moderator
There are after market adjustable thermostats.
Dusty
JFG
TN
Posted: 09/21/08 10:09am Link  |  Quote  |  Print  |  Notify Moderator
If you look at the side of the tank, you will see a disk type thermostat (about the size of a penney) with two wires going to it. Radio Shack has many to choose from rated at different temps.
I think on Attwood tanks, it's located below the electric element
* This post was edited 09/21/08 11:15am by JFG *
Fred
robatthelake
Vancouver Island
Posted: 09/21/08 11:18am Link  |  Quote  |  Print  |  Notify Moderator
I wonder if You cracked open the bypass valve allowing some Cold Water to pass through, it might act as mixing device?
I haven't tried this as My Hot Water isn't overly Hot!
Just a suggestion!
Rob & Jean 90 Southwind John Deere/Oshkosh/Freightliner Class A Ford 460/ Toad 92 Tracker 2 wd 5sp Convert Still running Great!
" Everything in it"Still" Works"
ScottG
Bothell Wa.
Posted: 09/21/08 11:48am Link  |  Quote  |  Print  |  Notify Moderator
Just a suggestion!
Thats a clever idea! That way it would be safer but you could turn the bypass back off if you need more hot water for showers.
Scott, Grace and Wesly
2003 Dodge 3500 4x4 Cummins (lightly bombed),
Hurricaner
Hurricane Utah
Posted: 09/21/08 11:54am Link  |  Quote  |  Print  |  Notify Moderator
These are not after market thermostats. They are made by Atwood. http://store.dan-marcrvparts.com/adeamoatwahe.html
I installed one 4 years ago, takes about 15 minutes.
Sam
