RV.Net Open Roads Forum: Class C Motorhomes: Greyhawk 33DS electricial issue
Open Roads Forum  >  Class C Motorhomes  >  Super C
 > Greyhawk 33DS electricial issue
Doug_H
Gold Bar, Wa
Posted: 09/21/08 08:55am Link  |  Quote  |  Print  |  Notify Moderator
I have a problem with my 07 33DS that I and the dealer and Jayco have been trying to figure out. So I thought why not bring it up here and see is anyone has had anything simular.
The levelers, rear camera display, and electric door locks do not work on their own. They will work if I hold in the AUX battery button. These are the only devices I know of at this time, there could be more. My feeling is these are all chassis battery powered and maybe there is a grounding or miswiring somewhere that is common to these devices only. The dash lights, radio, heater/AC, lights all work fine.
I'm open for ideas
Doug
'07 Jayco Greyhawk 33DS
'02 Jeep Liberty
enblethen
Moses Lake, WA USA
Posted: 09/21/08 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Look for a battery control center. It sounds like all the coach installed items are not functioning.
On many rigs there is an auxiliary relay that powers these items. In my coach, it looks like a Ford starter relay. It may be the same as the aux start relay. It could be as simply as a blown fuse.
Bud
Suzuki XL7 pushing Pace Arrow
Seneca
So. Ca
Posted: 09/21/08 09:48am Link  |  Quote  |  Print  |  Notify Moderator
On my Seneca, all of the items listed get their power and/or have relays behind the drivers side kick panel, just ahead of the door, by the emergency brake pedel. It is held in place by plastic clips and there is a mess of wiring behind it.
Its A Dry Heat
Arizona
Posted: 09/22/08 11:15am Link  |  Quote  |  Print  |  Notify Moderator
I would think that with this piece of information, they should be able to narrow the problem down to a few potential causes pretty easily if the right technician is on the job. I would have never thought of trying the AUX button myself.
I had a problem (self imposed) with my levelers on my 33DS when I inadvertently knocked an unprotected wire loose when sliding something in one of the pass-through storage compartments. I'm sure they've already checked those connections.
Good luck!
Doug_H
Gold Bar, Wa
Posted: 10/02/08 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Though I would let ya'll know that the problem ended up being a blown fuse down in that area behind the driver's side kick panel.
Doug
