RV.Net Open Roads Forum: Folding Trailers: Tire Wear
 > Tire Wear
mtkbuckeye
Clinton, Utah
Posted: 09/21/08 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2007 Fleetwood Arcadia. We went out this weekend and as I was emptying my fresh water tank and my hot water heater I got to looking at the tires and noticed that they were wearing on the outside and inside and not so much on the middle. Is this normal?
* This post was edited 09/21/08 03:57pm by an administrator/moderator *
2006 Ram 1500 Quad Cab Hemi 5.7L
"If we ever forget that we're one nation under (the one we trust on our currency), then we will be a nation gone under." - Ronald Reagan
trop-a-cal
Palm Coast Fl
Posted: 09/21/08 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
If the axle is flexing as you go down the road it will wear the inside and outside. That may indicate you have overloaded it. To stiffen the axle the flex has to be stopped by a block in the center and two arms going out toward the wheels. Spring shops and perhaps towing shops may have an aftermarket bolt on.
Sun Shoveler
Las Vegas,Nevada
Posted: 09/21/08 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
What presser are you running in your tires
red31
Bryan
Posted: 09/21/08 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
Under inflated or overloaded.
Not normal for properly inflated tires that are not overloaded.
Tire wear chart!
scpopupcamper
Lugoff, SC, USA
Posted: 09/21/08 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
Mine were doing the exact same thing....I switched to radials and have not changed another tire since. I used to be buying a tire every 18 months or so. been over 2 years now and have not noticed any tire wear. I should mention that I also had the axle straightened at the same time so it was one or the other...Martin
Martin Ray
Chuck&Gail
In the Colorado Mountains
Posted: 09/21/08 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
IMO if each tire wears on both inside and outside, tire is under inflated, or overloaded. Alignment should NOT cause wear like that.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
PopUpTom
Subject to Change, TN for now
Posted: 09/21/08 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
I have about 3000 miles on my tires and they have more wear on the outside than the inside. Not as much as yours, but similar. I had upgraded to a higher load rating tire, so it's doubtful I'm overloading mine. I'll assume it's normal wear for a bias trailer tire, but yours might be underinflated.
JFG
TN
Posted: 09/21/08 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
Your LR C tires are rated at a max of 1,760 lbs each. Your trailer probably weighs more than this loaded. Keep air at max side wall pressure and weigh trailer as soon as possible.
Fred
skipnchar
Topeka Kansas USA
Posted: 09/21/08 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
That is a classic sign of under-inflation of your tires or overloading of properly inflated tires. Cure if obvious. Pump them up to the max stamped on the side walls or stop overloading your trailer. Good luck /Skip
DRKMinWA
Olympia WA
Posted: 09/21/08 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
Well on a car that would be a sign of over inflation. Have you checked the tire pressure? Is it higher than the maximum listed on the tire?
Rick & Kathy
Washington
 > Tire Wear
