RV.Net Open Roads Forum: I have seen posts about parking with jacks down
 > I have seen posts about parking with jacks down
decan9
Oceanside, CA
Posted: 09/21/08 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
I cannot halp but wonder if it is not hard on the hydraulic system to leave a coach parked for weeks/months with the jacks down??? Someone want to convince mr otherwise?
Bonnie and me and Casey makes three!
Staying warm in Southern California
FMCA #402157
W9NCR
Sully2
Cincinnati
Posted: 09/21/08 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
I never parked my Southwind that had HWH hyd jacks for extended periods of time and wouldnt either.
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
Merlin44
We are in Tucson, AZ this year
Posted: 09/21/08 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
I certainly am not an expert and maybe a diesel is different. Once the air is out of the air bags, the jack are suppose to lock up. I don't think it is good for the unit to sit on the tires for long periods, also. Don't you get flat spots on the tires? I hope someone that knows, jumps in here. Maybe we are both all wet. HELP!
1998 American Eagle,40ft,325 Cummins engine,1 slide.
2001 Jeep Wrangler Toad, Blue Ox Hitch & Blue Ox Toad Break.
whisler6
Traveling
Posted: 09/21/08 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't do it but that is just my opinion
I RV to Live and Live to RV. When I'm not relaxing I'm posting on Forums . When I'm not here I'm over there, Where RvLivin.com and when I'm not there I am posting here at RV.net. Confused Yet?
Games
WTD44
Ca.
Posted: 09/21/08 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
IMHO, it doesn't hurt anything except the shafts might get tarnished if you are in a high salt area. Hyd. fluid is what is supporting the weight of the moho, and the valves which keep the fluid in the cylinders are made of steel or aluminum. Look at any construction crane, the boom is supported by hyd cylinders all the time. To my way of thinking, getting most of the weight off the tires and air bags is better than having it on them. I would think that the air bags should be deflated while on the jacks.
I too am no expert, but common sense tells me I am right.
'07 H.R. Scepter 40 ' PDQ
Cummins 400 ISL
Alison 6 speed World
'04 Jeep Wrangler X
Wife and,
Sparky the Wonder Dog
golfingflyfisherman
Denver, CO
Posted: 09/21/08 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
I park mine for the winter with jacks down to eliminate tire flat spots and relieve some of the pressure on the suspension and bearings.
Nomadac
Columbus, IN
Posted: 09/21/08 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Equalizer Jack system advised there is no problem with leaving the MH on jacks for extended periods of time. If you are concerned with corrosion on the pistons, you can recycle the jacks or take a rag and rub some hydraulic fluid on the pistons to prevent corrosion. Each time you recycle the jacks the piston is coated with hydraulic fluid. With my MH when you auto level it dumps the air bags while the jacks are extending. IMO taking dumping the air and taking the wt. off the tires while the tires are on boards or some type of barrier is better then waiting for the air bags to leak over time and still have the wt. of the MH on the tires and suspension.
Arnie
2003 Travel Supreme MH
38KSO1 Cummins ISC 350HP
Car Dolly w/1996 Toyota RAV4 2WD
1963 Pontiac Grand Prix
Nomadac
Columbus, IN
Posted: 09/21/08 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
Duplicate deleted.
CertifiedFunds
Middleburg, Florida
Posted: 09/21/08 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
It won't hurt anything.
'06 45' Tiffin Zephyr
'05 F350 Toad
DW Tammy & Son Gage
skipnchar
Topeka Kansas USA
Posted: 09/21/08 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
I'd MORE concerned about why you WOULD park with them down. Who's going to be annoyed at any movement if nobody's home?
