RV.Net Open Roads Forum: I have seen posts about parking with jacks down
 > I have seen posts about parking with jacks down
Wherever I happen to park
Posted: 09/21/08 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
Well, there are reasons to store jacks down.. however a Chuck implied, there is no reason from the jack's point of view save if they are FULLY extended. that is the only time I'd worry if they are at MAXIMUM extension
decan9
Oceanside, CA
Posted: 09/22/08 07:52am Link  |  Quote  |  Print  |  Notify Moderator
When the jacks are up. there is no pressure on the system. when they are down there is constant thousands of pounds of pressure on the system, since you are supporting part of the weight of the chassis. Sounds like pressure on the valves, hoses,etc. OK I'll put them down. I have HWH's..
Bonnie and me and Casey makes three!
Staying warm in Southern California
FMCA #402157
W9NCR
canttellu
Pennsylvania
Posted: 09/22/08 08:18am Link  |  Quote  |  Print  |  Notify Moderator
Every manual I've ever read (and I read them all) says to park with the jacks down, take the weight off the suspension and tires. Personally, I would ignore the answers from trailer owners, as they just don't apply.
MaverickBBD
Bellingham, Wahington, U.S.A.
Posted: 09/22/08 11:33am Link  |  Quote  |  Print  |  Notify Moderator
I store my rig indoors with the slides out so of course I have the jacks down. I do run the slides in and jacks up at least once a month. That seems to be the useage schedule. Have had not problems at all.
Tom, Cheryl & Maverick (Black Lab.-Great Dane Rescue)
2005 Winnebago Journey 36G w/Cat. C-7 350 hp on Freightliner XC
1994 Jeep Cherokee Sport Toad w/ SMI brakes
Roadmaster tow bar
FMCA 397030
WIT 129107
Pesident San Juanderers
sum1
So-Cal
Posted: 09/22/08 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
Jacks down for me.
mpmeisch
Aurora, IL
Posted: 09/22/08 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
wa8yxm wrote:
Let's see. You are going to let it sit there, Jacks PARTIALLY extended (Full extension is another matter) valves closed. If the sun heats thigns up and the hydraulic fluid expands a bit there is some room for expansion in the jacks so the pressure will not go out of bounds.. Likewise if it cools and contracts.
No, I don't see as that's hard on the system at all
Now leaving it with the pump running.. NOT GOOD but you never do that
You would have to be parked on the darkside of the moon to worry about temperature changes in hydraulic fluid and expansion. It just doesn't happen on a static system. It would be a guess, but I would have to say it would take a couple hundred degree or more change in temperature for hydraulic fluid to expand or contract if at all. You are perfectly safe parking jacks down.
Flying for work, cruisin' for fun!
2001 Itasca Suncruiser
