RV.Net Open Roads Forum: Ford 460 FI dies after 20 miles - FIXED Thanksl!!!
 > Ford 460 FI dies after 20 miles - FIXED Thanksl!!!
Page of 5
WGLASSJR
NORTH CAROLINA
Posted: 09/21/08 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
I would agree with the posts about the module.They really are not that expensive and not hard to change with the right tool.Keep us informed about the problem.
96Bounder30E
Birthplace of the Boysenberry, Orange County, CA
Posted: 09/21/08 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
bsinmich wrote:
I had that problem on my '89 460 and it turned out to be the catalytic convertor. Same problem happened twice.
I doubt this is his issue as a '96 model of the 460 wouldn't have a Catalytic convertor.......
John&Joey
Northern MN
(Baby it's cold outside)
Posted: 09/21/08 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
96Bounder30E wrote:
...I doubt this is his issue as a '96 model of the 460 wouldn't have a Catalytic convertor.......
You are correct, this model does not have one.
* This post was edited 09/21/08 06:38pm by John&Joey *
HWM222
Brockton, MA, USA
Posted: 09/21/08 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
I had a similar problem. It turned out to be a bad battery disconnect relay.
When it died, it wouldn't turn over. Wait awhile, and it would start up an run like a top...till next time.
Howard
Howard
John&Joey
Northern MN
Posted: 09/21/08 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
Howard
Starter turns over with no problems in my case. Thanks for the thought.
Daveinet
il
Posted: 09/21/08 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
Not specifically familiar with Ford, but if your coil is mounted external, if it fails, normally it would short out to ground. This means that when it fails, you could unbolt it and lay it loose on a piece of cardboard. If the vehicle starts, then you know you have a bad coil.
Engine compartments run very hot inside motorhomes, so premature failure of electrical stuff is pretty common. I've had coils fail on me on some of my cars and a few of my snowmobiles. All had the same symptoms, which are similar to what you describe.
Dave
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Thorley's & Magnaflows,
Howell/Edelbrock MPFI, Koni FSD,
Class A built for gear heads
My Revcon Website
Revconeers Forum
XP activation frustration
Jerry B
Ozark Highlands
Posted: 09/21/08 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
My 1996 did the same thing. Replaced the fuel pump. You don't have to drop the tank all the way down or drain the tank. We simply tilted it down on the right side and reached above the tank and replaced it. About $200 for the pump. Good luck.
Jerry B
1996 Dolphin 535,F-53.
T18skyguy
Eugene, OR
Posted: 09/21/08 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Another thing to check is the fuel pump relay in the fuse/relay box. They are cheap and easy to change. I carry a spare in my rig.
Retired Anesthetist. Pilot with mechanic/inspection ratings.1996 Jayco C 22 foot with 460/Banks Powerpak/Bilsteins.Wife and daughter. Two cats which control my life. 1975 Ford F-250, 84 Coupe Deville, Thorp T18, tons of tools and tons of junk.
never_be_rich
Illiniois
Posted: 09/21/08 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
John&Joey wrote:
Pirate wrote:
Yep, it's common until you change the fuel pump. Has yours been changed to the new style?
Prior owners records show on 8/99 "fuel pressure dropped after vehicle was driven. Performed fuel system diagnosis, found fuel pump going bad. Removed fuel tank and replaced pump. Installed updated wiring harness and reaassembled."
If you have the workorder, you may want to check the part number.
F6PZ-9H307-DA Fuel Pump And Sender Assembly (the last two characters are year)
Ford TSB 97-23-9
I met a guy this weekend who said he had to replace the pump twice because Ford had a shortage of the new style early on ...
Gale Hawkins
Murray, KY
Posted: 09/21/08 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Ford TSB 97-23-9
This was my initial thought as well. If the 99 replacement was of the old style (inventory setting on the shelve) it could have failed again. It seems someone recently covered how to replace with an in line fuel pump for this Ford issue.
Page of 5
