Jim@HiTek
Gresham, OR, USA
Wow, when I read these things about mileage, I'm kind of happy that my little 190HP Cummins pushes my 37&1/2' rig around at a solid 10.2MPG over the last 44,000 miles. Course I only weigh in at 23,000 lbs. with no slides, but it's comfortable.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site.
1994 Fleetwood Bounder
Cummins Diesel, 190HP, 36.5'
Black Rock Lava Park, Nevada
T18skyguy
Eugene, OR
I saw a show on fuel tank design that was real interesting. The inlet for the tank is placed so that the tank only fills to 80% capacity. It's to allow for the expansion of fuel as it warms up. If the tank would fill 100% it could potentially burst from this expansion. I do think it tends to skew the mileage figures of otherwise well intentioned folks.
Retired Anesthetist. Pilot with mechanic/inspection ratings.1996 Jayco C 22 foot with 460/Banks Powerpak/Bilsteins.Wife and daughter. Two cats which control my life. 1975 Ford F-250, 84 Coupe Deville, Thorp T18, tons of tools and tons of junk.
Preciser
Riverside, Ca.
Towing Jeep Rubicon 6.7 mpg
Not towing 7.7 mpg
2006 Mountain Aire 40'
1MTNEST
St. Albert, Alberta
I'm one of the guys that get 11mpg. Really. When parked.
Driving what ever speed is 6.8 - 7.6 really.
2007 Holiday Rambler Endeavor
40 SKQ 4 slides
ISL400 Cummins
Jeep Liberty Ltd/Blue Oxe, Even Brake
Life is not measured by the breaths you take, it's measured by the moments that take your breath away.
pfunk
Shelby Township, MI
T18skyguy wrote: I saw a show on fuel tank design that was real interesting. The inlet for the tank is placed so that the tank only fills to 80% capacity. It's to allow for the expansion of fuel as it warms up. If the tank would fill 100% it could potentially burst from this expansion. I do think it tends to skew the mileage figures of otherwise well intentioned folks. Correct, if you look at the bottom of any nozzle at the pump, youll see a little hole that when it sees fuel it shuts off the handle by using a diafram. In the fuel tank thier is a tube along side of the fillhose connected to a valve/vent in the tank, once gas hits the valve, it shuts off venting and allows the gas to fill up to the nozzle shutting it off
Fuel can expand as much as 6% over a 40-60 degree diference, the fuel system suppliers try to account for this through venting (hot day in AZ in ground temp at 65 degrees tank in vehical is at over 100)
2000 Holiday Rambler Endeavor
300 Cat 6spd Ally
George B
Northern CA
Depending on speed I get between 6.5 and 7.0 mpg figured mathematically over several tanks of fuel.
George B
2007 American Eagle
1999 Jeep Wrangler Sahara
2003 Harley Fat Boy
Enclosed Car Trailer
American Coach Yahoo Group
ANCHORAWEIGH
South Carolina
Just completed 12800 mile round trip to AK, 7.5 MPG.
Trevor & Janet
2006 Alfa Gold 40'
400hp Cummins/Allison 3000MH
2005 Honda Civic - Toad
Blue Ox Tow and Brake System
RCL
portola valley, ca
2004 Holiday Rambler Imperial, 400hp Cummins. 3200 miles from California to Connecticut, towing Jeep Grand Cherokee at 55mph...9.3mpg. Coming back, same route, same tow, same speed...8.8mpg. Differences: prevailing winds blow west to east, giving a boost to eastbound mpg; second was hit rain on westbound trip, increasing rolling resistance. Prior to dropping my average speed from 65 to 55, got somewhere around 7.7mpg.
Mileage numbers are off the Aladdin computer system in the motorhome. Have not yet checked it against fill-up data. Am waiting for enough fill-up data before doing that check.
deandec
El Dorado Hills, CA
I have a running spreadsheet of actual miles and gallons used for over 6 years cummulative. My 6 year average with a 300HP 8.3L Cummins and 33,000 Combined Vehicle weight with 40% Mountain driving and generator operation is 7.24 MPG.
Dean
95 CC Magna Jeep GC
(Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes.)
Hjudge49
St. Augustine, Fl.
2007 Beaver Contessa, 42', weight 39,000 loaded. Cummins 400Hp ISL. Just got back from a 12,000 mile trip to Alaska towing a Saturn Vue. Average 7.16 MPG calculated by actual gallons used. I have made no adjustment for considerable genset and Hydrohot usage. Used 741 gallons going to Alaska and 841 gallons after the new engine was installed in Fairbanks. Speed was 63-65 mph on interstates and around 58-60 on other roads, conditions permitting.
