RV.Net Open Roads Forum: Class A Motorhomes: A knocking while driving ....
 > A knocking while driving ....
2ndhom
Eugene, Oregon
Posted: 09/23/08 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
This is a shot in the dark question but sometimes someone will spark a thought. The 2006 Beaver 4 slide (new to us) has been working out great for us. Have not been able to put my finger on a LOUD knocking under the passenger seat (surrounding) area and toward the middle of the floor. Knocking is prevalent on some of the slightest bumps in a road driving slow (20 +) fast (55-). The noise is more of a deep knock than a rattle or squeek. We crawled/layed on the floor as well as placing our hands in various areas attempting to isolate. Also sat down in the lowest step area. Thoughts are ... a shock, loose floor or slide out step. Have crawled under (while parked) with flashlight touching and feeling anything within reach. Can't eyeball a thing that would be a-knocking. As a kid .... way back when, a knocking noise could be a bad shock .... before I begin the $$$$ witch hunt I thought I'd ask the experts .... get out your shot gun guys. Thanks. Tom
CSpenceFLY
Macon,Ga
Posted: 09/23/08 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
I would check all of the bushings,shocks,sway bars, etc.
"You're lucky to be alive my friend."
Quote from the "Do it yourself police" and many others that have known me.
NCRugRat
High Point
Posted: 09/23/08 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
After I replaced my shocks on my F-250, I had a similar knocking noise. The shocks felt tight, but I had to tighten them up even more and it resolved the knocking noise. Might be a good first step and I know it is an annoying noise.
2001 Gulf Stream Independence 8407
1999 Acura TL
rgraham
Missouri
Posted: 09/23/08 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
If you have dual wheels on the back check for a rock between the wheels, as I have heard of that doing that,
Richard
1987 ford f250 6.9 diesel
1997 Innsbruck by Gulf Stream 28ft fifth wheel with slide
and the wife and co-pilot Trudy
BobsYourUncle
Surrey, BC Canada
Posted: 09/23/08 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
What about an exhaust pipe of muffler having a loose hanger and vibrating upwards to hit the floorboards?
Does it make any difference if you are on or off the throttle? That is, does backing off or stepping on it change the condition?
Duramax / Allison
Fire Red
95 Sportsmen 25.5' TT
81 Citation 25' "Tail dragger" "Under construction"
"Workin' man's rig"
Check Out My Rebuild Project (Updated June 15, 2006)
Project Feedback
ArchHoagland
Clovis, CA, USA
Posted: 09/23/08 10:43pm Link  |  Quote  |  Print  |  Notify Moderator
I assume you have power jacks.
Try raising the front wheels off the ground and do some checking then for loose suspension items and, perhaps, a loose wheel but that would be pretty far fetched.
2004 Monaco
La Palma 36DBD
Two Slides
2 Potties
Workhorse 22 chassis
8.1 gas engine & Allison transmission
6.9 MPG based on a 6,000 mile trip around the U.S.
US Gear Toad Brakes
HIDEOUT
San Francisco Bay Area
Posted: 09/23/08 10:55pm Link  |  Quote  |  Print  |  Notify Moderator
Our last motor home had a weird knock coming from somewhere under the drivers seat. Never did figure it out, but it was kind of annoying. The new coach is as quiet as a mouse. Yea, right. How about the electric steps. Maybe it's out of adjustment. Just a thought.
Kevin
UPDATE:
Kevin my DH,
You forgot the knocking we had on CA highway 299 in our new motor home. The knocking was also under the coach and could be heard through the floor.
After parking for the evening, we found that there was oil leaking on the front passenger wheel. Winnebago (still under warranty) told us to have our brand new coach towed to Redding 50 miles over Buckhorn Pass. OH NO!
We contacted the wonderful folks at Four Wheel Drive in Redding, CA. (An authorized Workhorse Dealer). From our description, they advised that the problem was most likely a leaky bushing and if the front wheel was not loose, we could probably drive slowly to their establishment. So we did.
When we arrived, they fixed the leak in the front bushing and checked all the bushings for leaks. They also safety checked the coach and checked the under carriage for any more possible problems. The staff at Four Wheel Drive were wonderful and worked on our coach the same day as not to cause us further delay.
Dawn
* This post was edited 09/24/08 01:10pm by HIDEOUT *
Kevin & Dawn
Doggies:
Persalina, We love you & miss you so very much!
Moonbeam
Chloie Pearl
'07 Itasca Suncruiser 35L
Workhorse 24-8.1 Vortec w/6 sp. Allison
93 Jeep Wrangler Toad
Roadmaster Even Brake
Think before you Wink or Blink or Dink-a-Doo
C-Leigh Racing
Nashville NC
Posted: 09/23/08 11:13pm Link  |  Quote  |  Print  |  Notify Moderator
What about a mud flap flopping or a compartment door that needs tightening up.
Sometimes a noise produced can come from somewhere other than where you can feel it or think its comming from.
Our M/H has a valve rocker arm rattle sometimes from the right side of the engine & when you walk outside from the rear of the M/H up to the front on the left side, about half way up it sounds like the noise is comming from the muffler underneath the coach, but I know its a rocker arm.
Neil
RayChez
Barstow, Ca. USA
Posted: 09/23/08 11:25pm Link  |  Quote  |  Print  |  Notify Moderator
If you have steel rims with chrome caps, check the hub caps. They might be loose and they do make a knocking sound. Also check your tie rods, had a thumping sound on my pickup that I could not track down. I took it to a wheel alienment place and they replaced the tie rods. I was shocked when they showed them to me how worn the joints were. Noise disappeared after they changed them.
cdc
New Braunfels,TX
Posted: 09/24/08 03:51am Link  |  Quote  |  Print  |  Notify Moderator
It sound like you have a broken shock.
Corky, Gracie, and the Herd
HR Imperial DP
Jeep Liberty
