RV.Net Open Roads Forum: Tow Vehicles: Dodge Cummins Problem
Search only in Tow Vehicles
 > Dodge Cummins Problem
RayChez
Barstow, Ca. USA
Posted: 09/24/08 10:30pm Link  |  Quote  |  Print  |  Notify Moderator
This is actually for my neighbor who has a fifth wheel pulled by a Dodge 2004 with a Cummins 5.9 engine (2500 series).
Now the problem he has started yesterday when coming up to a stop sign the truck just died. He cranked it over and he finally got it to fire again to make it home. But as he arrived it stalled again. So we changed the fuel filter thinking that was the problem, but the engine will fire and run for a couple of minutes then die again. What do you guys think might be the problem.
SAS!
So. Cal.
Posted: 09/24/08 10:54pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the lift pump went. It should be located on the back of the fuel filter canister, it looks kind of like a roll of quaters. when you turn the key on it should buzz for a few seconds. if you bump the starter (don't start it) it should buzz for about 20 seconds. in 2005 they moved the lift pump to the fuel tank which is what they will do to your friends truck as the old style pumps are no longer availabe. Mine went at about 50k miles. it's a common problem. the lift pump is covered under the Cummins engine warranty for 5 years/ 100k miles with NO deductible. Many dealers will try to get $100 from you under the 7/70 warranty. you may have to take the owners manual with you to prove it. If he is out of warranty I have heard that the retrofit kit (just the parts) is $300-$400 from Dodge?
2008 Rage'n Falcon 34-05
2004.5 RAM 3500 QC 4X4 SLT SRW CTD 600
2001 Bombardier DS 650
2001 Yamaha Raptor 660
2004 Suzuki Z 250
CORVA........The Action Program........The BlueRibbon Coalition ........aSa
GaryGus
Sanger, California
Posted: 09/24/08 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
Do not drive that truck any further. I would also guess the pump is not operating. If it is driven too far, the injectors will get too hot from lack of fuel lubrication, and then you'll get to replace them too.
Gary and Donna
1997 Dodge 2500 Club Cab, Cummins, 4.10s, Banks Power, ATS Trans, EGR brakes
2005 Hitchhiker II 29.5 LKTG
"Greetings from the sunny San Joaquin Valley"
05-CTD
Las Vegas
Posted: 09/25/08 12:25am Link  |  Quote  |  Print  |  Notify Moderator
Here is a link to a place to get the replacement lift pump that mounts to the back the fuel filter. http://www.genosgarage.com/prodinfo.asp?number=PUMP_FPD4089602 A friend of mine with a 03 Dodge replaced his in about 45 mins. I think the in tank lift pumps are much better, but if one goes out in the fuel tank it would be much harder to change your self on the side of the road.
05-CTD 3500 4x6 auto
06 Rage'n FS2600 Toy Hauler
03 330 Magnum
04 600 Sportsman
vonzoog
Delaware
Posted: 09/25/08 05:59am Link  |  Quote  |  Print  |  Notify Moderator
SAS is 100% correct in everything he stated.
Mine started doing it about 20 miles from home when I caught a stop light. Boy does you heart sink when you are sitting at the light with traffic behind you and it won't start. Finally started and I got less than a mile from home and I parked it on the side of the road. The two dogs and I walked on home.
Had the truck towed to nearest Dodge dealer (insurance paid the tow) and they knew what it was and repaired it under warranty at no expense to me. I was out no money but had the inconvenience of losing the truck for two day.
FYI: I had 68k miles at the time. Has been running fine since the repair.
If you have to ask why I drive a Diesel, then you will never understand.
2004 RAM 2500 SLT Quad Cab 4x4
Cummins(305/355) 48RE Auto 11.5 Rear
2004 Laredo 29GR
vonzoog
Delaware
Posted: 09/25/08 06:03am Link  |  Quote  |  Print  |  Notify Moderator
Another note about the $100 deductible. My dealer printed out a computer report with my VIN number and said I would have to pay the deductible. I went and got the owners manual out of the truck and show them in print that I should not have to paid the deductible. They informed me they would have to show it to someone in the dealership that handle warranties. They next day they called me back and told me that I did not have to pay the deductible.
Hope this helps.
JIMNLIN
Big Cabin, OK
Posted: 09/25/08 06:22am Link  |  Quote  |  Print  |  Notify Moderator
made 05-CTD link a clickie lift pump which is a cheaper alternative to moving the lift pump to the fuel tank
Jim
'03 2500 Dodge/Cummins HO 3.73 6 speed manual Jacobs
'97 Park Avanue 28' with two slides
just me
Salt Lake City Utah USA
Posted: 09/25/08 08:11am Link  |  Quote  |  Print  |  Notify Moderator
Just wondering,You guys mentioned Genoe's are you members of the TDR?
95 Dodge CC #5 TST plate Flame Red/Silver
not totaly stock
2007 fiver
Tag Ma-haul has been suggested for a name but now The Shoe box
chrizg
IA
Posted: 09/25/08 08:53am Link  |  Quote  |  Print  |  Notify Moderator
TDR Member here
09 Big Country 2950RK
06 Dodge 3500 CTD 4X2 Mega Cab DRW B&W
RedRam
Moved from the smallest county in Texas
Posted: 09/25/08 09:41am Link  |  Quote  |  Print  |  Notify Moderator
You don't have to be a member of tdr to enjoy shopping at Geno's garage.Lots of chevy,ford and dodge forums support geno's.
