karmasasha
st paul minnesota , usa
If either pump or city water turned on the water in the commode will not stop running. Manual says check for foreign material where valve blade sits in flush hole. None found.
Any suggestions?
I was thinking maybe disconnecting the water line to the commode and adding an on/off water hose and spray. What do you think?
Thanks, Andrea
It is a Thetford Aqua-Magic Low
Andrea and Rommel the large gentle Rottie
Inga, my 1989 Winnebago Class A 27 ft (454 P30) with 100,000+ miles and going strong!
Dusty R
Charlotte Michigan 48813
I had one doing that. I took it apart and it looked OK. Put it back together, it stilled leaked. Bought a rebuild kit and put in it. Problem solved.
Dusty
wolfe10
What brand and model?
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
PapPappy
Wilmington, NC
It pretty much has to be a leaking seal. Go with the rebuild kit!
DH Bill / DW Claudia / DD Jenn / DS Chris
The Paps! Sophie, Abby, Brandy, Kahlie and Annie
Purchased April Fools Day, 2008
The Pets
enblethen
Moses Lake, WA USA
The seal in most Thetfords have nothing to do with the water valve.
The water valve or spring is bad.
Aqua magic but which model? II, IV or V?
Bud
Suzuki XL7 pushing Pace Arrow
karmasasha
Thanks guys. I can't find model number. It is a 1989 Thetford Aqua-Magic low. I will never be able to install a new kit by myself. (bad neck and arms) I found the water line in the back....could barely get my hands back there. I am going to take a mirror and flashlight and try to see what kind of connection to take line off. That would stop the water running. Then try and figure out a way for a hose and spray. That I think I could do but what a hassel to use so don't want to.
I checked for rv repair dealer in the area and no one lists toilet repair. Maybe I should drive to a Camping World and buy a new one ....seems like the installation cost might be cheaper than putting a kit in. Does that take long?
Is it the foot pedal area that I take off to put a new kit in? If I had easy access without taking off commode maybe I could try? I am not a quitter by nature.....just don't understand how to do it.
Thanks again, Andrea
Clay L
Sioux Falls, South Dakota
If you can remove the water connection, the hardest part of removing the toilet is done. There are two nuts on the base to remove and the toilet will lift up from the closet flange. With it on a bench, installing parts in the toilet is simple.
Maybe a friend could help.
Clay (WA5NMR), Lee,(Wife) Codi, Brandi (Shelties) and Damncat (damn cat)
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
enblethen
Moses Lake, WA USA
An 89 model is most like an Aqua Magic III if it has a mushroom shaped base.
These were unit rusted the mechanism. It may not be worth putting a new mechanism in it. They are over $125 plus labor.
A replacement Aqua magic V with a foot flush runs about $170. Decision time!
karmasasha
enblethen wrote: An 89 model is most like an Aqua Magic III if it has a mushroom shaped base.
Thanks!!!!! A new one it is!!!! Very helpful info. I am getting ready to head South to Texas so I am still going to try and disconnect the line and dump water in to flush and when I get to a Camping World will pull in and have them do it. (one in Denton, TX just off freeway) Sometimes the labor on new is cheaper.
