many questions
Omaha
last summer i founk a nice used camper but it had a bad smoke smell, how do you get rid of that smell, thank you very much
Jim-Linda
Livingston, TX
Rent an ozone generator, let it run a few day's, no more odor.
Jim
dodgerdog
Whittier California
Smoke smell as in campfire or smoke smell as owned my a smoker? I suggest washing anything that can be washed and fabreeze.... Plus maybe open it up and give it a good airing out.... Maybe put a fan inside to help move the air around...
Mike
steelpony5555
Copperas Cove Texas
Put out the fire 1st
If not too bad can try Fabrez or one of those sprays that kills odors and not just tries to cover it up hmmm sounds like a commercial---I think one is called Ooust or something like that
05 Trail Bay 27DS
07 Tundra SR5 4.7
00 Harley Electra Glide (My Baby)
07 Civic for cheap gas
Margarita machine---nothing better then sittin in the shade on a hot day sippin a Margie!
tvman44
Southwest Louisiana
Jim-Linda wrote: Rent an ozone generator, let it run a few day's, no more odor.
Jim
2nd on the ozone generator. Works wonders. Check with the rental stores.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
campingrandma
South Carolina
Ozium spray, it is an ionized spray and is MUCH cheaper than renting an ozone generator. Avaialable at most stores, usually in the auto department.
vic46
Red Deer, Alberta, Canada
Nilodor!!!!!!!!!!!
dhamblet
Olympia, WA
You can also put some fresh ground coffee in a bowl or 2 and set them in out of the way places. They will absorb the odor.
2005 Dutchmen 35SRV, Pergo floor, 5th Airborne, JT Strong Arm, Kodiak Disk Brakes, Backup camera
2006 Dodge CTD RAM QC 3500 LWB 4WD, Reese 16k, Airlift, Pacbrake, Britebox, 60g aux fuel tank
04 HD Ultra, CanAM 400MAX Quad
Spending my kids inheritance
Terryallan
NC
If it is from tobacco smoke. You may never get it out. If is from campfire smoke. Enjoy it, and go camping and add to it.
Terry & Shay
Pioneer 23T6
04 F150, 5.4, Lariat SuperCab
Lazy Campers
NC
havedreamwilltravel
If it is smoke smell from cigarette smoke you need to get the nicotine that's on the walls, ceilings, cabinets etc. using TSP (read to see what you cannot use it on as you probably have vinyl walls and ceilings) or some other type of cleaner - even 409 and a rag - just need to get that coating off everything. As long as the nicotine is coating the inside - it will smell. Get the carpets steam cleaned (not chem-dry type) everywhere there's carpet (underbed storage areas).
Wash everything washable, steam clean anything that's not professionally. Replace the Air conditioner filter if you have one of those. Run the air to "air" it out as well.
Ozone machine and febreze. It will take some work - but you should be able to get the majority of it out.
2007 GMC Yukon Denali - 6.2L 380hp/417ft-lbs,0-60 in 6.2 seconds
2007 Jayco Jayflight 27BH
Equalizer Hitch, Prodigy Brake Control
Our Truck and Trailer
Easy Trailer Mods-NEW pics added 4/10/08
Visited a lot of states, haven't camped in many...yet.
