RV.Net Open Roads Forum: Toy Haulers: WW stereo wiring diagram
Search only in Toy Haulers
 > WW stereo wiring diagram
lngwca2600
Visalia, CA
Posted: 09/27/08 01:46am Link  |  Quote  |  Print  |  Notify Moderator
Does anybody have a wiring diagram for the stereos on their WW? One of my rocker switches came unconnected and i want to reattach it. It is like a birds nest in that compartment......
Thanks in advance
2004 F150 SC FX4, 6" procomp stage II, 35" mud grapplers, Edge Evolution Programmer, Intake, Husky WDH 1400lbs, Prodigy
2007 WW FS2500 Billet, swivel rockers, all the goodies
2002 Yamaha Banshee
diver182
Ks.
Posted: 09/27/08 08:01am Link  |  Quote  |  Print  |  Notify Moderator
Just look at how the switch next to it is connected, they should be wired the same.
2007 Weekend Warrior SL 3005, Billet
2002 F250 CC 4X4 V10 3.73 Lariat
2007 Honda CRF150R
2006 Honda CRF250R
2005 KTM 250 SX
2005 KTM 85 SX
2003 Honda XR 100
Hap Hazard
Mammoth Lakes
Posted: 09/27/08 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
I'll expand your question. I would like to add outside speakers to my WW FSC2800 ('06). There are wires to the outside of the TH at the exterior location for the speakers and they are marked speakers.
However, when connected to speakers there is no sound on the rear connection. Does anyone have the wiring diagram so I can trouble shoot the system.
I agree it is a birds nest behind the stereo and there is no logic to the color code system of the wires.
Thanks
Hap
jmattor
Redondo Beach, California, USA
Posted: 09/29/08 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
I own an '05 FS2600 WW and I added outdoor speakers to the existing system.
Yes, there are wires located outside by the stickers applied at the factory, but No, they are not live.
You'll have to access the rear of the head unit and hook those wires up to a source. In my model the stereo is mounted in a wall cabinet and I got access by removing the bottom shelf inside the cabinet.
I also added a small amp to help boost the signal since the head unit alone isn't powerful enough to drive the outside speakers.
I don't have any "rocker" switches, that must be part of an option I don't have.
norcal_750
Alviso
Posted: 09/29/08 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
jmattor,
Do you have any pictures of how you mounted your external speakers? I have an 03 FS2600 and need some ideas.
LowRyter
OKC
Posted: 09/29/08 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
for some reason, both my outside speakers play the same channel. (left I believe)
4 THE TOYZ
SoCal
Posted: 09/30/08 12:51am Link  |  Quote  |  Print  |  Notify Moderator
Mine too lowryter. My outsides are both the same channel and the inside bedroom are also on one channel. The 4 speakers in the galley/kitchen are fine, both left and right. Why????
2007.5 GMC 2500 CC Diesel-6"Pro Comp Lift 35" Toyo M/T, Air Lift w/on-board compressor + other mods
2009 Weekend Warrior LED3505
2007 Rhino 660 with several mods
2001 Honda TRX-90 (For the little one)
MCR500
Central Calif.
Posted: 09/30/08 08:01am Link  |  Quote  |  Print  |  Notify Moderator
WW uses a four channel deck, so if you want to run the (4) inside speakers, and the (2) outdoor ones, you need to wire it this way.
Take the leads of both left side, inside speakers, and plug them into the "front left" speaker output. Take the leads of both right side, inside speakers, and plug them into the "front right" speaker output.
My stock Sony deck in my SLC had a "pre-amp out" RCA plug in the back, which controls the REAR channel speakers. I took an RCA cable out of that plug, and ran it to an amp that I mounted on the cabinet above the sink. The amp has its' own, dedicated 12v supply that I ran from the breaker panel, with a inline fuse. I also wired a lighted 12v toggle switch to the face of the cabinet(next to the gas guage) to control on/off of the amp. I took the OUTSIDE speaker leads, and ran them up the back of the cabinet, and connected them to the L/R output of the amp.
Soooo, if you want to listen to music on the (4) indoor speakers, use the fade control on the deck, fade to "full front", and the (4) inside speakers play.
If you want to listen to the (2) outdoor speakers, fade to "full rear", throw the toggle to power the amp, and the (2) outside speakers play. If you fade to "0" or center, and the amp is on, ALL the speakers play. Works GREAT!! Make sense???? Hope this helps, C-Ya!!
04 WW 3705 SLC All the options!!
05 Ford F350 CC DRW 4x4 6.0 w/ power"enhancements"!
Toys:
97 Honda CR500(dads)
05 KTM 525EXC(dads,Cal. Plated!)
05 Honda TRX-250(#1 son)
05 Honda TRX-250(#1 daughter)
98 LT-80(#2 daughter)
00 Big lawn chair(#1 wife)
4 THE TOYZ
SoCal
Posted: 09/30/08 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
Thx MCR500. After reading that, I think I will leave it as is...
LowRyter
OKC
Posted: 09/30/08 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
I think I'll take that info & my RV to a car stereo shop.
