RV.Net Open Roads Forum: Travel Trailers: changing gears
 > changing gears
Anita Swanson
Fouke
Posted: 09/28/08 08:19am Link  |  Quote  |  Print  |  Notify Moderator
Changed from 350s to 410s in the diff of our ford f150 with 5.4 eng. Has anyone done this? I am wondering if it will make much difference in towing? Have not towed yet.
pete42
Jamestown, Ohio
Posted: 09/28/08 08:23am Link  |  Quote  |  Print  |  Notify Moderator
While I have not changed my gearing I also have the 350's I get 9 mpg towing 15 solo.
I have a friend in Florida who changed his gearing and his mileage went down.
you should tow much easier.
Hornet28BHDS
Parker, PA
Posted: 09/28/08 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Your F150 should tow better, but you may see a small decrease in mileage.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
goldendagger
moving
Posted: 09/28/08 09:28am Link  |  Quote  |  Print  |  Notify Moderator
your tow milage will go up, empty will go down.
who left the light on? is it me or are we leaning downhill. where did the dog run off to
smkettner
Posted: 09/28/08 09:42am Link  |  Quote  |  Print  |  Notify Moderator
Yes it will make a difference. You will be pleased.
matt7591
So. CA
Posted: 09/28/08 10:02am Link  |  Quote  |  Print  |  Notify Moderator
disregard
 > changing gears
