RV.Net Open Roads Forum: Class A Motorhomes: Driving lights
 > Driving lights
krickster
Posted: 09/28/08 10:30am Link  |  Quote  |  Print  |  Notify Moderator
Hi, just curious, when do you use your driving/marker lights? Do you always use them at night, or just when you need to be seen? Thanks!
brobox
Sunny SW. Florida
Posted: 09/28/08 10:50am Link  |  Quote  |  Print  |  Notify Moderator
Mine point everywhere but on the road, no matter what I have done to keep them pointing straight. Now I use them to flash truckers when it's clear to come back in my lane.
Chuck
02 Travel Supreme, 2 street side slides
02 Jeep Liberty Toad
T bone
Top O Texas
Posted: 09/28/08 10:55am Link  |  Quote  |  Print  |  Notify Moderator
I use my DRL all time. If in a vehicle without DRL , I turn on regular lights.
MAKE SURE THEY SEE YOU, USE HORN, LIGHTS AND SIGNALS.
1999 Georgetown 325S,V-10 Ford.
2002 Ford Ranger Edge toad
carrying a 2001 Yamaha Warrior.
DrScud
On the Road
Posted: 09/28/08 11:04am Link  |  Quote  |  Print  |  Notify Moderator
Use them all of the time. I want to be seen
Jim & Sim - Fulltiming. - - Follow our adventures at: JimandSim.com
98 Foretravel U320 40', Cummins 450 HP/1450 lb-ft, HD4060 Allison, w/rtrder
2000 Jeep Grand Cherokee Laredo / M & G Braking / Demco Excali-Bar
Current location
itsalleasy
My markers come on with the headlights, which I also use anytime I drive. If you mean regular low mounted driving lights, only if no one else is around, same as brights. Those can be blinding to have in mirrors if you are in a car or to have to drive into.
Harvard
51.37N 114.42W
Posted: 09/28/08 11:48am Link  |  Quote  |  Print  |  Notify Moderator
Daytime Running Lights (DRLs) are mandatory in Canada. DRLs in Canada only turn on a front pair of non coloured lights. These are the lights, when we travel in the USA, that some of our American friends think that we have forgotten to shut off.
bsinmich
Holland, MI
Posted: 09/28/08 11:52am Link  |  Quote  |  Print  |  Notify Moderator
DRL come on as soon as I start the motor. The marker lights do not come on unless I hit the headlights. I also have a DOT switch that will flash the marker lights on if they are off, or off if they are on. This is supposedly an aid when trucks pass. I think they are almost invisible in daylight and I haven't been out in the dark yet with the headlights needed since I got the MH. I don't recall having to drive any of my MHs in the dark more than 1 time. For us dark is sleep time.
2003 Newmar Mountain Aire, Workhorse W22, & 2002 PT Cruiser w/Remco lube pump, Falcon 5250, & US Gear Unified Tow Brake
LVJ58
Las Vegas, Nevada
Posted: 09/28/08 11:59am Link  |  Quote  |  Print  |  Notify Moderator
For the most part I only use mine at night as the Lincoln Navigator headlights my coach builder used in our coach leaves much to be desired for illuminating the roadway.
Jim & Sherry Seward, FMCA #F342207
2000 Residency 3790 V-10 w/tags
2003 Suzuki XL/7 Towd
kaydeejay
SE Michigan, USA
Posted: 09/28/08 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
All GM products have had DRLs from the mid 90s so I'm not sure how you would stand out as being different from thousands of other vehicles on the road.
Keith J, Retired from GM Engineering
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA.
1999 Sunnybrook 27RKFS Fiver
Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors.
Harvard
51.37N 114.42W
Posted: 09/28/08 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
Our habitual routing is a Snowbird route on Highway 93 from North Western Montana, Idaho, Nevada and thru to Yuma (and back). On these routes, Nevada and North, you sometimes drive for an hour without meeting an oncoming car. But you are right about your observation if we were to be driving on an inter state divided highway in Eastern and Central USA.
 > Driving lights
