RV.Net Open Roads Forum: Class C Motorhomes: 1996 Shasta 25' Class C
 > 1996 Shasta 25' Class C
jemmie
Carmel
Posted: 09/28/08 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
I am looking at buying a 1996 Shasta 25' class C on Ford E-350 frame with 7.5L engine. The vehicle has only 22,000 miles on it.
I have rented a motorhome before but have never owned one, but am somewhat mechanically inclined. I checked it out today and from a layman's perspective it looks fairly good for a 12 year old vehicle. The engine could probably use a tune-up and the current owner has owned it for 2 years and 2000 miles and did not do any maintenance.
I think I can get this for $10K. A few questions:
1) From what I can tell on the various RV for sale web-sites, that looks like a pretty good deal. Is it?
2) What specific potential problem areas should I be looking for? I looked around ceiling and walls to find signs of leaks and found one small one. Is that a big deal? What is a big deal in terms of repair costs on these vehicles?
Thanks.
-JW
trnfla
Tampa
Posted: 09/28/08 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
check how old the tires are.
Have a great time camping,
Terry
Please say a Prayer for my 12 month old Granddaughter VisitBella.com
Please visit my Photos and Blog NiceCamps.com
Now 2004 Winnie 31C
Had
2007 Zeppelin EZ190, 2007 Expy
1999 30' Dutchman Classic 5th wheel, 2005 F250
Roadfrog
Chilliwack, BC Canada
Posted: 09/28/08 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
I'll chime in on question 2...
If it were me, I'd pay a local RV dealer/repair facility to take a moisture meter and check all around the unit, especially where you suspect the leak. Then, have them do a SealTech (or similar) check. Then you'll know where you stand. A leak (especially if it's been leaking for a time), is not something to take lightly. Don't ask me how I know.....
Cheers
Chris
1999 Winnebago Itasca Spirit 29N
1988 Campion Allante 195
Gale Hawkins
Murray, KY
Posted: 09/28/08 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
Where it is a good deal or bad deal most often is not known until 90 days after purchase. The 460 is a good engine and if not removed and replaced expect one or more exhaust manifold bolts are broken and maybe a warped exhaust manifold. That issue is on the 460 and 454 are as common as snow at Christmas in MI.
All leaks are a big deal until they are fixed but with Eternabond so far all of ours have been fixable with little cost. The leaks will stop when you fix the right spots. Actually most of us shot gun it by doing all the common seams and leak points. Leaks seem to take more time to locate than shops seem to want to take in my experience. Check out your overhang as a common leak/stress region.
You could have brake and other issues duing to having been parked most of its life. If you do not have to get new tires or a transmission then $3K in parts and service over the next year or two should cover getting it ready for a trip across the US and Canada.
Being handy is good and almost a requirement when owning and old rig especially the has been let go. There is a good chance the brake and transmission fluid have never been changed for example.
Let us know how it works out for your.
jemmie
Carmel
Posted: 09/28/08 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the quick responses. A few things:
1) The tires are new. The owners had to replace it very recently because of dry rot.
2) The couple is selling because the man now has Parkinson's, is on disability, and they can no longer afford to maintain it or even really to use it. They have put on less than 2,000 miles in two years. I met the man in person today and verified the story (his physical movements resembled Muhammed Ali's). Why all that is important is because it's less likely that they are selling it because it's a piece of junk and because of their life situation.
3) It sounds like it would be a good insurance policy to get it checked out at an RV service center for leaks, mechanical issues, etc. How much should I expect to pay for that?
Thanks.
* This post was edited 09/28/08 10:34pm by an administrator/moderator *
Handbasket
Asheville, NC
Posted: 09/29/08 05:09am Link  |  Quote  |  Print  |  Notify Moderator
Check the tire pressures and oil, then take it for a test drive on a 4-lane amongst fast-passing trucks. See if it tracks reasonably well thru their wind wake, or makes your knuckles turn white. If you can do this with a full fresh water tank to help simulate a full travel load, so much the better.
Jim, "Be the coffee!"
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison ('Loafer's Glory'); '07 Forester 2.5 ( the 'HANDBSKT'); '95 Toyota SR5 V-6 4x4 pickup, ARB locker, Bilsteins, Warn hubs & M8000, etc;
'94 968, M030 swaybars ('DOPPLER')
