RV.Net Open Roads Forum: Around the Campfire: 3 way switch in stick house
Open Roads Forum  >  Around the Campfire  >  Humor/Jokes
 > 3 way switch in stick house
6Quigs
CA
Posted: 09/29/08 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Maybe the bulb is blown
Bounder 34VS
Kajtek1
CA
Posted: 09/29/08 10:31am Link  |  Quote  |  Print  |  Notify Moderator
Dick A wrote:
Kajtek1 wrote:
Took me quite some thinking to work the 3-way switches in logical system and I am good at it .
Yep, there is the Kris's way and then the correct way!
....Kris, I just couldn't resist kidding you.
That's what makes this forum fun, doesn't it?
I was trying to memorize several wiring diagrams some publications present, till I come to simply conclusion. Black screw on first switch needs to be connected to the feed wire, the black screw on the other to the bulb. The other 2 screws need to be connected between switches and it doesn't matter if you cross it.
The same adding 4-way is just cutting into the 2 wires between the switches.
Really very basic, although not seeing the wires in the house can be quite confusing.
Pessimist sees dark tunnel, optimist sees a light at the end, realist sees lights of coming train.Engineer sees 3 idiots on the tracks.
Orion
Pacific South West
Posted: 09/29/08 11:12am Link  |  Quote  |  Print  |  Notify Moderator
I just went through this in my house. I wish I could somehow get a copy of the page into my posting as it explains it very well.
I'm thinking that the reason for the confusion is that the switches are wired differently depending on how it is laid out. There are THREE different diagrams here for the wiring depending on whether the light itself, or the fixture, is AFTER, BEFORE or BETWEEN the switches.
Also the light junction box itself is wired differently for each variation.
Never miss an opportunity to walk on the grass.
Benntexas
Posted: 09/29/08 11:52am Link  |  Quote  |  Print  |  Notify Moderator
ok here you go TWO internet diagrams that work.
http://www.danswiringpage.com/html/3ways_101.html
and then there is this link.
http://www.danswiringpage.com/html/best_3way.html
mikhen
oley, pa
Just a few of the ways it can be done.
2002 Avalanche 2500
2006 Fleetwood Terry 300BH
Equal-i-zer
Tekonsha P3
Beer
Deb and Ed M
SW MI, USA
Posted: 09/29/08 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
I wired our entire house (extensive remodel job) using my "Black and
Decker Home Wiring Guide" - it has VERY easy-to-understand diagrams, including various ways to wire a 3-way switch :-)
Deb
T bone
Top O Texas
Posted: 09/29/08 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
There are only 3 wires in each switch box red,white and black. The light is between the two switches.
1999 Georgetown 325S,V-10 Ford.
2002 Ford Ranger Edge toad
carrying a 2001 Yamaha Warrior.
mikhen
oley, pa
Posted: 09/29/08 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
It would be the 1st diagram I posted earlier, you just have to verify which color was used for your common. It could also be a bad wire in the box at the light.
