RV.Net Open Roads Forum: General RVing Issues: RV toilet leaking
 > RV toilet leaking
TexasDiesel
Posted: 10/01/08 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
Our Sealand toilet sprays water out the back through an assumed crack in a fitting. Doesnt look replaceable atleast I cant find service parts for it.
Questions:
All all RV toilets interchangeable?
Any suggestions how where to buy a new one?
Any one paticular toilet better?
TIA
01.5 Dodge/Cummins 3500 DRW 6 sp 4wd | 98 Dodge/Cummins 2500 QC 5 sp 12V (no CAT) | His: Honda Silverwing 55MPG scooter, Hers: Kymco Xciting 250 80MPG scooter | 35' H.R. Presidential (fulltime) | NRA |
enblethen
Moses Lake, WA USA
Posted: 10/01/08 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
Parts for Sealand must be purchased through a Dometic dealer.
Most RV toilets are interchangeable. There is a bolt pattern problem with the old Thetford Galaxy. Sealands are normally pretty good units.
I have a Thetford and if I needed a replacemnt, I would goiung with another thetford porcelain bowl model. The Augua-Magic style II, about $250 or Style Plus for about $265.
All Thetford should be available at or through most RV retailers.
Bud
Suzuki XL7 pushing Pace Arrow
TexasDiesel
Posted: 10/01/08 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, I found a Thetford Aqua MAgic V new for $113 incl shipping on EBay.
enblethen
Moses Lake, WA USA
Posted: 10/01/08 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
You may want to go to a dealer and "try out" the Aqua Magic V. It is kind of flimsy with the small pedestal.
Carvin Marvin
Livingston, Texas, USA
Posted: 10/02/08 06:40am Link  |  Quote  |  Print  |  Notify Moderator
I suggest you take it off and determine what is leaking. If it is the plastic fitting they are a replacement item at nearly any RV supply. You could use a mirror and see where the spray is comming from.
Chris Bryant
DeLand, Florida, USA
Posted: 10/02/08 07:59am Link  |  Quote  |  Print  |  Notify Moderator
Leaking in the back is *usually* a bad vacuum breaker- an easily replaceable part.
To replace the Sealand with the Thetford you will have to turn the floor flange and reroute the plumbing.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
enblethen
Moses Lake, WA USA
Posted: 10/02/08 11:30am Link  |  Quote  |  Print  |  Notify Moderator
Mr. Bryant is correct. The vacuum breaker does fail. If you are happy with other aspects of the toilet, why not fix it? You do have to find a true Dometic retailer to get part.
TexasDiesel
Posted: 10/02/08 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
Will try that idea this weekend.
 > RV toilet leaking
