emtee
West Virginia
Just realized last night while hooking up- my 16K Superglide has no hole for a handle lock. I have been dragging my 5er around for several years with nothing to lock the jaw handle in place. It has a "barb" on the handle that snaps in behind the plate, but nothing else. Anyone else have this setup? Is it OK like it is? You'd think Pullrite would have put lock provisions in if they deemed it to be needed.
What do you guys and gals think? Drill a lock hole in the handle? Leave it alone? What????????
Mark and Lucy T.
2004 Chevy 2500HD Gasser
2008 Jayco Eagle 27.5 Super Lite
Superglide on Homemade Removable Rails
Dennis Bham
Alabama
emtee wrote: Just realized last night while hooking up- my 16K Superglide has no hole for a handle lock. I have been dragging my 5er around for several years with nothing to lock the jaw handle in place. It has a "barb" on the handle that snaps in behind the plate, but nothing else. Anyone else have this setup? Is it OK like it is? You'd think Pullrite would have put lock provisions in if they deemed it to be needed.
What do you guys and gals think? Drill a lock hole in the handle? Leave it alone? What???????? See this post: Superglide Lock
A padlock in the position shown in this photo prevents the handle from being lifted past the "barb" stop:
'08 Chevy 2500HD Duramax 4x4, Crew Cab, Std Bed e/w 18K Superglide
'08 Cougar 292RKS, e/w 16" Sendel wheels & BFG Commercial TA tires
PressurePro TPMS
wa8shc
Parma, Ohio
I've been doing what BHAM showed in picture above.
Just put padlock into top part of the handle hole & handle wont have enought room to lift past the 'barb'
Works just fine in my case
JMHO
Denny WA8SHC and Rita WB8TIR
Siberian Husky Ta'kya (Princess RIP 10/04 Taz RIP 5/12/08)
2007 Dodge Ram 2500 Quad Cab 5.9L CTD 3.73/LSD,Quadzilla RECON monitor
2008 Rockwood 8243S 5th wheel
Pullrite 14K Superglide & MorRyde pinbox
emtee
West Virginia
Great link Dennis. Thank you. While reading that thread, there is a slight bit of controversy whether the lock is needed or not. However, I am not concerned with the jaws opening during a tow (I already have the red paint on the jaws and do a pull test 100% of the time). It would be almost an act of God for the pin to be slack at the EXACT same time I hit a pothole HARD ENOUGH to bounce the handle. That just ain't gonna happen. But if it did, I would be picking up truck bumpers and rims and tire fragments and suspension parts and.... No, I am more concerned with punks and the like yanking on the handle when I'm parked. I always do a walk around when we leave the trailer for any length of time (at rest stops, etc), but I COULD miss that. And yes, it would be easy to pull the jaws open if I was parked in such a way that the pin just happened to be slack in the jaws. I just thought it might help deter a potential inquisitive kid (or drunk adult).
Think I'll go ahead and put a little lock in the hole. No mods required and mission accomplished.
Camping Dutchman
NJ
I didnt even realize and that bugger is in there pretty well after be latched, with the spring tension etc.. Might be something to consider.
2008 Chevy 3500 cc DRW Duramax
2009 Cedar Creek Silverback
2004 United Specialties Sold
Member:Good Sam Club Haulin Highlanders
Dennis Bham
Alabama
The reason I put the lock on mine is to insure that a prankster does not maliciously release my hitch while I'm away from the rig temporarily. It would be easy for me not to notice that it had been released ...
I'm not worried about it bouncing loose ... heck, it always takes a good hard pull to release it ... nothing IMO that a bounce could duplicate ...
Dennis
edited 10/03/08 02:53pm by Dennis Bham *
smkettner
When you slap the lock in the handle hole put the e-brake cable on the lock also and you are set to roll.
fivecodys
Central California
smkettner wrote: When you slap the lock in the handle hole put the e-brake cable on the lock also and you are set to roll.
That's a heck of an idea.
Thanks for sharing.
Bill
2007 Tundra DC
SuperGlide 14K
Prodigy Brake Controller
2009 Flagstaff 8528RKSS
Air Lift 5000
"So is Congress the opposite of Progress?"
ol Bombero-JC
Edit = dbl post.
edited 10/04/08 01:46pm by ol Bombero-JC *
ol Bombero-JC
Padlock hole has been on here a lot.
At first I thought the OP was talking about these SG failure/problems:
These two threads should be . . . "SuperGlide REQUIRED READING"!)
"Pullrite Superglide hiccup" (spelling as indicated)
by "my3wags" -on- 4-24-07
Also -
"Superglide Hitch by Pull-right" (spelling as indicated)
by "capnit" -on- 9-28-06
will require advanced (archive) search.
Maybe somebody can link that - I can find 'em, but linking glitch (me?).
JC
