RV.Net Open Roads Forum: Class A Motorhomes: Slide Gaskets Not Properly Deploying
 > Slide Gaskets Not Properly Deploying
jomarfl
Tampa
Posted: 10/03/08 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
Hello,
Can we get a picture of where and what it looks like?
Thanks
Papa John & Mother Mary
Living The Good Life In Tampa, FL
Retired Military, USAF
2008 Fleetwood Fiesta LX, 34N w/bunks
dougrainer
Carrolton
Posted: 10/03/08 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
The seals you are talking about do NOT seal the room. They are called "WIPE SEALS" and just as they are called, they keep outside air and elements from coming into the RV when the room is extended and retracted. The reason to "flip" them in or out is just for your own peace of mind and will not affect the actual seal of the room. Doug
speckchaser
lafayette, la 70501
Posted: 10/03/08 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
Doug is correct per the service techs at Newmar.
Jerry and Nelwyn
2005 Kountry Star 3910
lionel_046
Ohio
Posted: 10/04/08 07:32am Link  |  Quote  |  Print  |  Notify Moderator
Doug is also correct per the techs at Damon. However, the one time I didn't flip the seal out on my BR slide last year I got wet. We were in a pretty good rain in SC and the slide leaked - only time it ever leaked. I had my dealer do a water check for over an hour and no leak discovered. Not sure what to think now. Harry
Harry & Gail
USAF Retired
2003 Damon Intruder 350, W-22
2002 Chrysler Sebring Convertible
on a 2006 Master Tow Dolly
dougrainer
Carrolton
Posted: 10/04/08 09:03am Link  |  Quote  |  Print  |  Notify Moderator
I should have mentioned-- The best way to make the Wipe Seals flip in and out is to install the non skid tape (2 inch width if you can find it) that uses tape adhesive about 6 iches from the inside flange wall. The skid tape will not harm the rubber and will flip the wipe seal. Doug
dougrainer
Carrolton
Posted: 10/04/08 09:07am Link  |  Quote  |  Print  |  Notify Moderator
In the rain, it is normal for some water to get in when retracting. The Wipe Seals are not weathertight. They keep the majority of water from coming in. Doug
lionel_046
Ohio
Posted: 10/04/08 10:31am Link  |  Quote  |  Print  |  Notify Moderator
Doug,
Agree, and I should have been more specific. We were camped and asleep in the bed when we started getting water leaking through the slide seal area.
Harry
david_w28
Michigan
Posted: 10/05/08 09:29am Link  |  Quote  |  Print  |  Notify Moderator
If the seal is partly out at the bottom and in at the top you will get water passing behind the seal. This happened on my last MH. On the one I have now the seals do not flip out but stay in-ward. After careful checking I determined that the water will not pass behind the seals when they are either fully out or fully in. Mine are all the same way (in-ward) so why touch something that I don't have a problem with.
mscamping
any place, USA
Posted: 10/05/08 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
I installed a 1" wide rough rubber non-skid tape within an inch of the rubber molding on the slide and it has worked every time so far.. Don't get the kind with sandpaper type nonskid it will sand the molding and damage it.. I got mine at Ace Hardware.. You can buy it by the foot or a whole roll(60').. Hope this helps..
2003 Holiday Rambler Neptune 36 PBD 37' - ISB 300 Cummins w/Allison MH2000 5 speed
2005 Malibu Maxx w/Blue Ox Aventa II SMI Stay-n-Play Duo
FMCA - HRRVC - Chapters - 56,57,& 419 - Good Sam Life Member - C2C - Coach Net - full timers
Mike & Sharon
