9452772
Schertz, TX
My trailer was bought with four Marathon 225/75 R15 load range C tires. On the last trip one of the tires was seperating so I went to the local tire shop and all he had was one Maxxis load range D tire. Of course I had him install it and all is good. Now I would like to replace the other three. Technicly all I need is C rated tires but I like the way the D rated sits under the trailer. I was right at the max on the C rated tires. I will have to order the other three Maxxis D rated tires or I could get four Carlisle E rated tires and Keep the one Maxxis D rated tire as a spare. Any thoughts on the Maxxis D rated tire vs. the Carlisle E rated tire for my situation?
Thanks,
M&R
Schertz, Tx
2001 Ford F-250, 7.3, auto, long bed, 4x4
Autometer guages, 4" MBRP exhaust, AFE STAGE 2 intake
285/75-R16 BFG, 4.10 gears
2004 Nomad 2805
Mayoman
Tennessee
I just put Maxxis E's on my 5er. I think they are the better tire.
2008 Ford F450 Superduty Diesel dually
2008 Keystone Cougar 293SAB
DianneOK
Donnelly, ID
With 2 blowouts in 600 miles and the other 4 Marathons bubbling and separating, we replaced all 6 with Maxxis Es. Much happier and safer now......
Dianne
Donnelly, ID
DataStorm
HAM WB6N (Terry)
2005 Teton 39' Frontier Grand
2003 Freightliner FL60
Life Member Good Sam
Escapees
Geocache..."RVcachers"
RV net Blog
gorjo01
Eastern Ontario
Unless your rims are rated 80 psi you should get Maxxis load range D. If your rims are rated 80 psi get the Maxxis load range E and forget the Carlisles. Maxxis is probably the best 15 inch ST tire there is. Very few, if any, negative comments about Maxxis ST tires. The same cannot be said about the Carlisles. A search on "Carlisle tires" on this forum will provide you with much insight.
SH
Lynden, WA
After having a brand new Marathon blow out, I purchased Denman E rated and opted for new rims. Personally, I would have gone to 16 inch rims if I would have been able to fit them on our rig!
2003 Springdale 279
2007 Chev 2500 LMM Duramax/Allison
1993 Heritage
1989 Sporty
USAFBILL
Alabama
Sure is confusing for us that are looking to replace them before heading South for the winter...I have a hard time finding a source for Maxxis in Alabama.
gorjo01
Eastern Ontario
USAFBILL wrote: Sure is confusing for us that are looking to replace them before heading South for the winter...I have a hard time finding a source for Maxxis in Alabama.
You can have them delivered to your door after ordering them from various online tire stores or by ordering them direct from the Maxxis store at Maxxis.com.
jim87vette
Arizona
Maxxis E on the 5er they are a great tire so far,just keep your pressures adjusted and check often.
08 GMC 3500 Dually Duramax
96 Chevy 2500 6.5
05 Yamaha Rhino
04 Gearbox 335FS 5er 14k wet
johnrbd
Hanford, CA
If your trailer weighs less than 9000 loaded, the Maxxis D will do the job, especially if your rims can only handle 65 pressure.
dadwolf2
Henderson,NV,USA
My Marathons were separating too and I replaced them with Maxxis. Haven't had any trouble yet.
2005 Dodge Ram 2500 CTD,4X4,NV5600,Pullrite superglide
2005 Skyline Rampage 289
Suzuki z400 & z250
Honda XR250
