RV.Net Open Roads Forum: Have you used the self-stick tiles on your floor?
 > Have you used the self-stick tiles on your floor?
robatthelake
Vancouver Island
Posted: 10/05/08 01:07am Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't recommend them! For about the same $ You can install Laminate!
JMHO
Rob & Jean 90 Southwind John Deere/Oshkosh/Freightliner Class A Ford 460/ Toad 92 Tracker 2 wd 5sp Convert Still running Great!
" Everything in it"Still" Works"
fatmanobx
kill devil hills, n.c.
Posted: 10/05/08 04:17am Link  |  Quote  |  Print  |  Notify Moderator
I hate stick down tile. But....I just put some in our A's bathroom and it was very easy. I was at Home Depot and they had a tile that looked like real tile on sale for $1 a square foot. It really does look like tile. Just wanted to add that I also bought a seam glue kit that is used on Armstrong sheet vinyl and treated every seam just to make sure the water wouldn't get in the cracks and cause failure.
2003 Four Winds Infinity 37'
Dick_B
Palos Heights, IL USA
Posted: 10/05/08 05:47am Link  |  Quote  |  Print  |  Notify Moderator
I agree with the `preparation' post. I did a tile floor in the kitchen and used CertainTeed Fiber Cement Underlayment instead of plywood because of the presence of moisture. It handles just like plywood and can be cut with a Utility Knife. I'd suggest screwing it down.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Heir Max
membership 1/16/2001, Bay Minette, AL
Posted: 10/05/08 07:48am Link  |  Quote  |  Print  |  Notify Moderator
I put 18" self sticking tiles in the bath. Did the same prep as Rob. Now, we just wipe the water up when the shower door leaks some.
99 Tradewinds
2000 Explorer Toad
bill h
coastal reconquista
Posted: 10/05/08 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
We used self-stick squares in a fiver that was a perm in a park on the Colo River. It got really hot there, even though we had a beehive ventilator over one roof vent. And, of course, it got down into the teens every winter.
We scrubbed the vinyl floor with a wax remover, then Scotchbrite and Spic and Span, then rinsed several times, to be sure of good adhesion. These were Armstrong tiles, so decent quality.
The tiles did not stay exactly where they were placed. It was very disappointing, since we both worked hard to make every detail of the fit perfect.
84 Barth 30 tag powered by ht502/Thorley, Gear Vendors OD
Siamese Calvin and Airedale Hobbes
4WD Toyota toad
chipndip
Madison, AL, USA
Posted: 10/05/08 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
I installed the self adhesive tiles with mixed results. I'm certain that temperature is more of a problem than flexing. Good prep is a must but I would use some additional adhesive as well. I have also had better success with the 8"x36" strips than the 12" squares.
computerbug
Sarasota
Posted: 10/05/08 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
We have put them down in 2 rvs tiles were purchased at home depot. We live near the beach so they have been exposed to sand and water. Never had a problem. Real easy to install.
CptSD
Yuma, Arizona
Posted: 10/05/08 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
alpenliter wrote:
I tried the peel and stick 12" tiles and like an earlier poster said, prep is everything. I would suggest TrafficMaster "Allure". It's a floating floor (adheres to each other) in 36"x8" strips. When I bought mine it was available in only 3 wood patterns, now they have fake tile, granite, cork, bamboo, etc. It is very easy to work with and best of all is only about $1.69 a sq ft.
I'm not sure I understand what you mean by a "Floating Floor" are you saying that they stick to themselves somehow and not to the actual floor? If so how does this work?
It seems to me that if this is the case it would be much easier as far as floor prep?
Thnaks for the post, JB
alpenliter
Olympia WA
Posted: 10/05/08 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
Yes JB a "floating floor" is either a floor that locks together like laminate or in my case adheres to each other instead of being adhered to the floor. There is a lip of about one inch on the underside of the plank with adhesive and a matching lip of adhesive on the top of the adjoining plank. (See picture) They work like contact cement with each other. The reason I prefer this vinyl plank flooring over laminate, is if there is a water emergency, you don't have to worry about it swelling, as it is waterproof. Been down two years now and doing fine.
2004 F-450 CC, DRW 6.0 Classy Chassis
1997 33' Alpenlite St. Andrews
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Alpenlite Travel Club #5955
Vietnam Vet '67-'68
Extreme Makeover RV Style! Click here!
