RV.Net Open Roads Forum: Dinghy Towing: Towing a Nissan 350 Z
Search only in Dinghy Towing
 > Towing a Nissan 350 Z
John95683
Sacramento
Posted: 10/04/08 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
I own a 2007 Nissan 350 Z with the six speed manual transmission, which the manual says is towable four down. Does anyone here town a 350 Z, and are there any problems? I can't seem to find anyone that make a base plate, and I'm also concerned about ground clearance. Thanks for your help.
Al B
Cowtown
Posted: 10/05/08 11:06am Link  |  Quote  |  Print  |  Notify Moderator
I don't see a problem. DW drives the RV, you drive the 350! All kidding aside, if the manufacturer states that it is towable, then I would tow it. For the ground clearance, do you worry about the ground clearance when you drive it day to day? I'm sure on certain instances you would be careful when driving day to day, but I think if you carried these same precautions when towing the car, nothing has changed. If it's lowered... buy a trailer.
