RV.Net Open Roads Forum: Class A Motorhomes: Fuel Injection?
 > Fuel Injection?
RonAllen
SouthFlorida moving to Pensacola,FL
Posted: 10/04/08 07:48pm Link  |  Print  |  Notify Moderator
What year did Ford and Chevrolet do away with carburetors on motor homes and start using fuel injection? I am in the market for a MH but think I should buy one with fuel injection.
RonA
fredbon
Pacific Northwest or SoCal
Posted: 10/04/08 07:54pm Link  |  Print  |  Notify Moderator
Ron, I am by no means an expert, however if the unit has a For V10 or a GM 8.1L engine it will be fuel injected. I am sure there will be other GM engines that are FI.
fred
Fred and Bonnie
Frankie & Scarlett, (The Cats)
2005 Dolphin LX 6375
2006 Saturn VUE
As I've Matured... I've learned that artificial intelligence is no match for natural stupidity.
avidude
I had a 1989 Southwind on a Chev P30 Chassis. It had a carb. I believe that was the last year on the 454.
Ted
'07 Bounder Diesel 38S
Cat C7 300hp, Allison 3000MH
Tow: '11 Chevy Tahoe LTZ
LVJ58
Las Vegas, Nevada
Posted: 10/04/08 08:52pm Link  |  Print  |  Notify Moderator
My neighbor has a 91 coach with the Ford 460 and it has port injection. The GM 454's used throttle body fuel injection, but not sure what year(s) either changed over from the carburetor system.
I'm sure as this thread progresses there are those who know for sure and can answer your question with accuracy.
Jim & Sherry Seward
Las Vegas, NV
2000 Residency 3790 V-10 w/tags & Banks System
2003 Suzuki XL/7 toad
427435
Rochester, Mn
Posted: 10/04/08 10:03pm Link  |  Print  |  Notify Moderator
Ron,
Look at 2000 and newer MH's with either the Ford V10 or the Chevy 8.1 engines. Not only will you be getting a good engine, but also a better chassis.
Mark
2000 Itasca Suncruiser 35U on a Ford chassis, 80,000 miles
2003 Ford Explorer toad with Ready Brake supplemental brakes,
Ready Brute tow bar, and Demco base plate.
Daveinet
il
Posted: 10/04/08 10:18pm Link  |  Print  |  Notify Moderator
You have to be very careful specifying by year. Most chassis are older than the Motorhome model year. Depending on the brand, it can be as much as two years different, unless you are buying an off brand, then up to 4 years. If you just go by chassis year, GM went to TBI somewhere between '90 and '91. Chassis year '96 went to the Vortec motor which is port injected and significant bump in HP.
Of course you can convert anything. Mines an '83 with a '95 GM TBI computer adapted to port injection. TBI only benefits cold starts and altitude compensation. Technically a carb will atomize the fuel better than TBI and if set up correctly should out perform it. The big advantage with port injection is that it allows for a more versatile intake manifold design.
IRV2
D.R.Bain
Michigan
Posted: 10/04/08 11:19pm Link  |  Print  |  Notify Moderator
RonA
Ron,
I had a 86 Chevrolet with carboration and a 96 chev with throttle body injection. Both chassis were of the preceding year.
Dan, 2007 Damon Daybreak 3270
KOG
Winterville GA
Posted: 10/05/08 12:38am Link  |  Print  |  Notify Moderator
The 454 in MHs never used throttle body injection, went straight to port injection for the '90 model year and got OD transmission at the same time. Chevy small blocks used throttle body in the late '80s.
Brian in Michigan
S.E. Mi.
Posted: 10/05/08 04:43am Link  |  Print  |  Notify Moderator
My was chassis was built in "89". The MH is considered a "90" it has a carb I believe it was the last year for GM to have a carb.
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS, Thorley Headers B&M trans cooler. Flowmaster mufflers recurved distributor Still Keepin on Truckin((((Was 7.5mpg Now 8.75mpg ))))
itsalleasy
Posted: 10/05/08 05:43am Link  |  Print  |  Notify Moderator
I know that's wrong, I have a 1990 P30, TBI with a turbo 475.
1989 was the transition year for the P30, some carbs, some TBI. OD trans was used starting in 1991.
 > Fuel Injection?
