RV.Net Open Roads Forum: General RVing Issues: InstaGone
 > InstaGone
Roadfrog
Chilliwack, BC Canada
Posted: 10/04/08 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
I already posted this info on another forum, but thought I'd enter a post here....
For those that have tried it, they'll know how good this stuff is. I tried every product and device I could, trying to remove black mold and mildew stains from the acoustic carpeting on the ceiling of my 99 Itasca Class C. Some water intrusion had caused some staining as described above. I tried bleach, Simple Green, Folex, Bissell Carpet stain remover, with and without a steam machine, etc. None made any difference and then I read on someone's post that they had tried, and had good luck with, InstaGone. Suspicious, but eager to try just about anything, I ordered a bottle and it arrived in a few days. The instructions said to just spray it on and let dry - no blotting, wiping, scrubbing, nothing, which made me even more skeptical. Anyway, as instructed, I sprayed and waited....and within about 5 minutes the stains literally dissappeared. Sounds like a TV commercial doesn't it? Apparently it works on all stains on pretty much all surfaces. I haven't tried it on anything else yet, but I'll be curious to see how it does. I already got my moneys worth and I hardly used any of the product. I have some more mold stains to deal with after I get my rig back from the dealer. Here's a link to the product:
Instagone
Cheers
Chris
1999 Winnebago Itasca Spirit 29N
1988 Campion Allante 195
LakeN
North Carolina
Posted: 10/04/08 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks very much! I need the Instagone for a home shower issue with mold that is persistent!!
'08 Toyota Tundra 5.7L with tow package/Prodigy
'09 Heartland North Trail 26RKS
2 campers + 1 spoiled golden retriever, Daisy
Admin
Channel Islands Harbor, Ca.
Administrator
Posted: 10/04/08 11:20pm Link  |  Quote  |  Print  |  Notify Moderator
I'll give it a try.
Thanks
Admin
Hornet28BHDS
Parker, PA
Posted: 10/05/08 08:46am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the good review!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
Skid Row Joe
On the road in America
Posted: 10/12/08 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
Appreciate the tip. My fabric walls and ceiling in SOME areas of my coach are looking soiled in dirt the past year and a half or so.
My unit is 6 years old, and the ecru colored fabric around the entry door, and driver's window are starting to look dingy.
I have a sweet tender nature, however I enjoy sharing my thoughts and opinions.
Fulltiming RVer & homeowner.
MonacoRon
Nawth AlaBamma
Posted: 10/20/08 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
I received my Instagone packets today. In reading their application instructions and uses, I don't see listed use on fabrics other than vinyl type fabrics (lawn chair cushions, etc). Do I understand from your post that you did use it on a fabric ceiling with no negative results? My ceiling is an off-white and I am concerned that my nice dark ceiling stain may be replaced by a brite white non-stain. :-)
Ron
Nawth AlaBamma
Roadfrog
Posted: 10/21/08 11:37am Link  |  Quote  |  Print  |  Notify Moderator
If it's like the acoustic beige carpeted material I have on my ceiling, It did not bleach to white. It simply removed the black stains! Very good stuff.
 > InstaGone
