RV.Net Open Roads Forum: Travel Trailers: Leveling and stabilizing with slideout question
 > Leveling and stabilizing with slideout question
chi6488
florida
Posted: 10/06/08 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Ok, here is my procedure.
Level trailer side to side with lynx levelers as needed.
Unhitch trailer from truck.
Level front to rear with hitch.
Stiblizers down.
Slideouts come out. Both are on the right side of trailer standing at hitch looking back.
I did this last trip out and noticed that my left side front stabilizer was raised a bit after the slideouts came out. The front slideout is rather long. It has a sofa and the u dinette. I didn't notice this unitl 2-3 days later. I thought the trailer was kind of wobbly. I tightend up the front left and all was fine.
2009 Jayco Eagle 324BHDS
2008 F250 King Ranch 4wd
2005 GLacier Bay 2670 Cat
downtheroad
Puget Sound
Posted: 10/06/08 08:55am Link  |  Quote  |  Print  |  Notify Moderator
Exactly what we do..except I go back around right away after I move our slides out and re-tighten the stabs as needed.
Also I'm sure you chock securely before you unhitch.
"If we couldn't laugh we would all go insane"
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Picture
Reese Dual Cam HP
chi6488
florida
Posted: 10/06/08 09:24am Link  |  Quote  |  Print  |  Notify Moderator
So if this is normal then I guess I will have to compensate leveling side to side for the slideout.
wayne_tw
South Dakota/Georgia
Posted: 10/06/08 09:31am Link  |  Quote  |  Print  |  Notify Moderator
that little bit of rise caused by the weight of the slideout is not enough to worry about.
pdvandusen
Snow Hill, NC USA
Posted: 10/06/08 09:53am Link  |  Quote  |  Print  |  Notify Moderator
I have found that after about 24 hrs. I need to tighten the stabilizers as the base seems to compress the ground. I've never had one "swinging in the air".
Doug & Mary Ann Van Dusen and Phoebe (the dog)
2008 Chevy 1500 Silverado 5.3L LTZ 3.73, HD Trailer Pkg.
2008 JayFeather LGT 31E
Equal-i-zer, Prodigy BC and TomTom GPS
The dreaded Champion Generator
Hornet28BHDS
Parker, PA
Posted: 10/06/08 10:10am Link  |  Quote  |  Print  |  Notify Moderator
Your procedure is right. The stabilizers will need adjusting after a few days, which is completely normal.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
Paul B
Daytona Beach, Florida
Posted: 10/06/08 10:55am Link  |  Quote  |  Print  |  Notify Moderator
I've learned to level so that after the stabs are down the weight of the slide will bring TT back to level, then a slight readjustment of the oppsite side is all that is needed.
Paul B
2001 Excursion-Powerstroke Diesel
2000 Honda CRV
2006 Flagstaff 31' - 7.5k lbs.
2004 Two Honda EU2000i's/parallel cables/extra fuel tank
shenandoahvalley
Shenandoah Valley, Virginia
Posted: 10/06/08 11:23am Link  |  Quote  |  Print  |  Notify Moderator
Our slide is fairly small, sofa only, but I put a 12x12x2 block under each of the stabs and we don't seem to have any settling issues.
S.K.
Broadview Heights, OH
Posted: 10/06/08 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
I have read some other posts that recommendeded getting the slide out first before putting down the stablizers. Does anyone do this? I don't do that because I don't feel too comfortable walking around inside the camper without the stablizers down (to remove the slide traveling lock).
Robin1953
Belle, WV
Posted: 10/06/08 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
Owner's manual in new Copper Canyon fiver says to level trailer before deploying slide. Does not mention anything about stabilizers. I had a Prowler TT with a slide that said to level and stabilize prior to deployment of slide. May be dependent on type of RV.
Robin Brumfield
2004 Ford F350 PSD XC
2008 Copper Canyon 241FWSLS
