RV.Net Open Roads Forum: Class A Motorhomes: Tow capacity
 > Tow capacity
nuthinfancy1
Posted: 10/06/08 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
I'm probably not in the right area but none of the others seem to apply sooo-
I am purchasing a 2004 39' Winnibago Chieftain. The owner told me it has a tow capacity of 5000. Does that sound right? I know he has a Blue Ox on it and am wondering if that is the capacity of the Blue Ox. I'd like to be able to tow my rockcrawlin Jeep on the 19' trailer that I currently use.The trailer does have electric brakes.
I know I should wait until I get all the paperwork on the MH but I pass papers on my house the 27th, take possesion of the MH on the 28th and head to NC -where I have a job waiting-ASAP
Thanks for any enlightenment
fourfurz
Memphis
Posted: 10/06/08 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
I suggest calling back the owner and get all the weight specs for the coach. I'm sure he would be glad to help you.
The Blue Ox is not part of the coach, it's an add-on for flat towing a car. If you're going to be using a trailer, then you'll be connecting it with the standard hitch directly, no Blue Ox required.
2007 Mountain Aire 4528
2006 CRV SE
Based in Memphis area
427435
Rochester, Mn
Posted: 10/06/08 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
If you go to the Winnebago web site and look around a bit, you'll fine that they have the specs and literature of their older models on it. You should be able to get the info you want from there.
I do think that it is likely 5000 lbs----at least my older Itasca is.
Mark
2000 Itasca Suncruiser 35U on a Ford chassis
2003 Ford Explorer toad with US Gear brakes,
ReadyBrute tow bar, and Demco base plate.
Deen
Vancouver, WA
Posted: 10/06/08 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
It could even be as low as 3,500#'s. Our DSDP is 6,000#'s but that's the llimitation of the hitch, Spartan says the real limit is 10,000#'s with only a hitch change. We usually tow the Ody on the dolly and the Ody is loaded for shows so I suspect we're really close to the 6,000# limit. Ody bare is 4,400, dolly is 600#'s+ and then the show inventory.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
69RoadRunner
VA
Posted: 10/06/08 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
What is the capacity of the hitch?
What is the GVWR and GCVWR of the MH?
What is the typical loaded weight of the MH?
How much does the loaded trailer weigh?
09 Newmar Ventana 3942
SteveRankin
Sequim, WA
Posted: 10/06/08 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
According to the data on the RV Consumer's Group CD, the Chieftain has a towing capacity of 4,000#.
The other issue is tongue weight, as MH's in general don't handle tongue weight well and long gassers are especially prone to problems with tongue weight because of the length of chassis behind the rear axle. A 500# tongue weight is typical for many DPs, so this is probably a deal killer IMHO. If the Jeep weighs 4000# & the trailer weighs 2000#, the TW will be 720-900# (12-15% of trailer weight).
Steve & C. J.
"Gracie" the Rough Collie & "Bo'sun" the Bichon Frise
2009 Arctic Fox 29V
2005 Chevy 2500HD Duramax 4X4 Crewcab
PullRite 20K# hitch
TruControl Brake Controller
Our Beaver Technical page
Wildlife rescue at the Northwest Raptor Center
Bumpyroad
Virginia
Posted: 10/07/08 06:03am Link  |  Quote  |  Print  |  Notify Moderator
which blueox tow bar do you have? my Aventa II has a 10,000 lb. capacity.
bumpy
1995brave
San Antonio, TX
Posted: 10/07/08 06:15am Link  |  Quote  |  Print  |  Notify Moderator
According to Winne specs (here) you have a 5,000 lb hitch.
nuthinfancy1
Posted: 10/07/08 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Thanks folks for confirming my fears
I guess I'll have to use the BlueOx and keep my AAA gold card
or
Find a diesel
75k sound like a good deal for the 04 Chieftain with 10,0000 miles and loaded with all options?
Comparable diesel? Over 100k?
Clay L
Sioux Falls, South Dakota
Posted: 10/07/08 08:50am Link  |  Quote  |  Print  |  Notify Moderator
You may not be able to tow something as heavy as the hitch rating allows.
You are not supposed to exceed the GCWR (gross combined weight rating). That is the weight of the motor home plus the weight of what you want to tow.
Look HERE for a lot of info on motor home weight ratings.
Clay (WA5NMR), Lee,(Wife) Codi, Brandi (Shelties) and Damncat (damn cat)
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
 > Tow capacity
