RV.Net Open Roads Forum: Tech Issues: Adapter 15amp/30amp to 50 amp
 > Adapter 15amp/30amp to 50 amp
Kejsj30
Portland, Oregon
Posted: 10/06/08 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
The whole 50 amp discussions seem to take a wierd twist on here but, can someone tell me wether or not this would really work?
http://cgi.ebay.com/ebaymotors/Parts-Acc........%3A12%7C240%3A1318&_trksid=p4506.c0.m245
2008 Chevy Silverado 2500HD
2008 Keystone Raptor 3712TS
2000 Bayliner 2855 Sierra SunBridge Boat (SOLD)
2007 Raptor 700R
2007 YZF 450RSE
2008 Raptor 700RSE
Learjet
Louisiana
Posted: 10/06/08 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
doesn't work with GFI receptacles, they are many versions of these.
edit: meant to write Doesn't..corrected
* This post was edited 10/07/08 07:58am by Learjet *
2006 Nissan Titan CC with tow package
2006 KZ Frontier 2303P-F
Equal-i-zer
Prodigy brake controller
Yamaha EF2600c Tri-Fuel Gen.
hershey
Albuquerque,(fulltime) NM, USA
Posted: 10/06/08 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
I have one that I purchased several years ago for $99.99. It does work as advertised and it WILL NOT work with a GFI plug. I don't know how it can be built for 30 bucks considering what the plugs sell for.
You need to remember, your not going to get the total of 100 amps that your present 50 amp RV is looking for, but you will get a total of 50 amps instead of only 30 amps without the unit. So your only ahead by 15 or 20 amps. But that makes it doable with energy management.
hershey - albuquerque, nm
Someday Finally Got Here
NASCAR 20 - - 99
CA Traveler
Sun Lakes, AZ
Posted: 10/06/08 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
hershey is right on that it doesn't work with a GFI plug and the rest of his post. This ebay device is known as a cheater cord (and other names) and there are many related posts on these boards.
They work and can be useful. HOWEVER they can cause problems depending upon the CG configuration and other information. The discussions on these boards involve in/out of phase circuits and neutral over loading. It's very technical but the posts are available.
2004 Holiday Rambler 36 Endeavor PST with ISC 330 Cummins
2004 Honda CR-V
Bob
flhtci-rider
Montreal, Canada
Posted: 10/06/08 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
also if the CG has the 2 plugs wired on the same pase you can burn up their wireing cause your breaker may be on your post and the post in the panel may not be fused.
2006 Scepter
2008 24' Haulmark EDGE
2008 Grand Vitara
My best friend DW
1 fur ball Max (AKA - PITA)
And enough solar power so I never have to start the Gen Set
Golden_HVAC
Fulltime, CA, USA
Posted: 10/06/08 10:53pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I am not absolutly positive, but the box sates "UL Listed" and I have a difficult time finding that true. The UL labs would find this dangerous, because it has two input plugs and one output.
If they hooked it up to a stove, turned the stove burner on, and then plugged in one of the plugs, they would quickly find that the other plug sparks if it is near a metal surface, causing the product to fail it's safety "Giggle Test".
While I would build and use one if I had a 50 amp RV, I could not use it at the following places, and that means about 95% of the RV parks I have been to recently.
Any RV resort with a 20 amp GFI, it will not work, and NEC code requires a GFI in most "Wet" locations, so if the power post is outdoors . . .
At Morro Bay, the feed to each site is #10 wire protected by a 30 amp circuit breaker, that is always locked up, only the Ranger and other staff can re-set the circuit breakers, and the 20 amp and 30 amp receptcal are both fed from the same circuit breaker, 1 for each site. This type of set-up it will not work in.
At another campground, I had two power receptacles for the double site. In this case, if management allowed, and there was not a second camper in the double site, I could use the two 30 amp receptacles with a device like you described, but management considers this stealing power, and would kick me out of the park if they find and confenscate such a device. It is in the rules of some parks. They consider it a danger to their wiring system, right or wrong, it is their rules.
So where I would have a place to use one? I don't know.
There are simple ways to load share. Without getting one of these devices or upsetting the management. You can use an extension cord to power your electric water heater and refrigerator - if they have external power cords, just plug them into a #12 gauge extension cord, and plug that into the GFI protected campground power plug.
If you have a 30 amp and 20 amp circuit breaker and the feed is more than 30 amps to your site, then you could use whatever the water heater and refrigerator use together along with 29.5 amps to power other things in the RV.
I find that I use my voltage booster more often than the 30+30 to feed a 50 amp RV would be used.
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a Porsche or Country Coach!
If there's a WILL, I want to be in it!
Improve a life KangenPowerTeam.com Akaline Water.
I havn't been everywhere, but it's on my list.
Escapees.com
Bumpyroad
Virginia
Posted: 10/07/08 05:49am Link  |  Quote  |  Print  |  Notify Moderator
well Fred has pretty much said it all but I wonder just how well an airconditioner will run/start up on 15 amps, especially if there is a bunch of other stuff on that circuit.
bumpy
Hurricaner
Hurricane Utah
Posted: 10/07/08 06:03am Link  |  Quote  |  Print  |  Notify Moderator
Fred, look closer it says, installer of UL listed equipment, not UL listed.
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
kaydeejay
SE Michigan, USA
Posted: 10/07/08 06:52am Link  |  Quote  |  Print  |  Notify Moderator
In fairness his listing does say:
"NOT FOR USE IN PARKS WITH GFI RECEPTACLES."
but the whole idea of this providing a 50A service is just plain wrong. Perhaps it provides HALF of a 50A service. (50A @ 110V but certainly not 2x50A @ 110V).
Keith J, Retired from GM Engineering
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA.
1999 Sunnybrook 27RKFS Fiver
Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors.
Kejsj30
Portland, Oregon
Posted: 10/07/08 07:26am Link  |  Quote  |  Print  |  Notify Moderator
I really don't have a use for it because its seldom that I have hookups when camping but, came across it last night on Ebay and found it strange.
I knew everybody on here would know wether or not its a good idea or a bad idea.
Thanks,
