RV.Net Open Roads Forum: Tow Vehicles: 2008 GM 3500 with 6.0 gas automatic?
Search only in Tow Vehicles
 > 2008 GM 3500 with 6.0 gas automatic?
retento
Rocky Mount N.C.
Posted: 10/07/08 04:41am Link  |  Quote  |  Print  |  Notify Moderator
2008 GM 3500 dually with 6.0 gas, automatic. Anyone towing with this setup? If so, then what and how much do you tow? Hills, mountains flat ground? Mileage? What's the max. fifth wheel tow capacity? 10500#? I know the D-Max/Allison is about 8K more and it's rated at 16500#, I tow with a 8.1/Allison now and was wondering if anyone had given the 6.0 gasser with the six speed Hydramatic a try. I'm not trolling or fishing!! Just wondering, cause I never hear or read about anyone with this setup....... And I'm wanting a new truck!!
Justardnck
Loxahatchee, FL
Posted: 10/07/08 04:55am Link  |  Quote  |  Print  |  Notify Moderator
I don't know, I used to love my 6.0L until I started towing heavy weight with it
2003 GMC Sierra 2500HD, EC, LB, 4X4, 6.0L, 4:88 gears, 6" Fabtech suspension lift on 35" tires
2006 Coachmen Adrenaline 228 FB/TT
The Equalizer hitch with a Primus brake controller
Just the woman, myself and Beuford our Rottahoula (yeah... you read it right)
just_dave
Bay City, MI
Posted: 10/07/08 05:41am Link  |  Quote  |  Print  |  Notify Moderator
I have to agree with the above, unless they've done a lot with that motor, I'd say you'd run out of engine long before you'd run out of truck. I don't understand why you'd put a 6.0L in a 3500, it sort of defeats the purpose of a beefier truck, doesn't it? - Dave
2001 2500HD 6.0L 4.10 4x4
1999 Jayco Eagle 285BHS 5er Thank you Lord!
Draw-Tite 16K with Kwik-Slide
Prodigy
Bilsteins (on the truck)
Monroes (on the 5er)
Roady2 XM Radio
Perception Swifty 9.5 Kayaks
M GO BLUE
Southgate, MI
Posted: 10/07/08 05:43am Link  |  Quote  |  Print  |  Notify Moderator
Big truck, little engine...never has made any sense!
ERIC & BEV
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fith wheel
Built-In Onan 5500W generator
Turbo Diesel Dude
Green Mountain, NC
Posted: 10/07/08 05:46am Link  |  Quote  |  Print  |  Notify Moderator
Taking a knife to a gun fight.
charles weidman
Rollincool
Always Rollin
Posted: 10/07/08 09:39am Link  |  Quote  |  Print  |  Notify Moderator
The 8.1 is a torque motor. The 6.0 is a rev motor. 2 different animals. If you do a lot of hilly driving pulling a trailer, then no doubt, get the diesel. If you only pull once in a while, and mostly flat areas, get the gasser.
If you like smoother less revving, less shifting, get the diesel.
The 6.0 will do what you ask, but it will let you know it's doing it.
The duramax, on the other hand will do it pretty much flawlessly.
Mileage is a bit better with the diesel, but you're paying for it off the start. (and don't tell me resale is better. Of course it is, you paid for it when you bought it)
I had the '03 duramax when we pulled our trailer, it was smooth up and down. That engine did everything I asked it to do.
I know have an '08 reg cab 4x4 gasser. I use it to plow and pull things around. We have a motorhome now, so I got rid of the diesel, and the price was right on the 3500 gasser.
I pull my car trailer and have pulled up to 10,000lbs. It WILL pull it. The 6L90 is a nice transmission. But, there is a difference because of the torque. The 6.0 seems to want to rev up (which is typical for a gas motor) and constantly shift. Once you get used to the shift pattern, you can use the manual button and use it to your advantage.
So if you ask if I were to buy a duallie, (not a reg cab, which I have now) which engine I would get, I'd answer the diesel, hands down.
You'll really be happier with it. JMO
-Joe
2008 Chevy Silverado 4x4 3500 RC/LB 6.0
2007 Chevy GS Conquest Super C 6340DK
2007 Chevy HHR Toad 2LT 2.4
1990 Chevy G20 Cargo Van 305
1967 Chevy Camaro Pro Street 468/650hp BBC
My 70's Show - Tom Kent Radio Network - KLTH - K•HiTS 106.7
jim87vette
Arizona
Posted: 10/07/08 10:10am Link  |  Quote  |  Print  |  Notify Moderator
I had the 7.4 454 for many years and it worked great for most applicatins but once I got into the 10k and up trailers it didn't perform very well and labored hard.Bought a Duramax 3500 08 and haven't looked back since, the truck is a pure workhorse!If I wasnt pulling heavy say 7k and under I would of kept the 454 Dually.
08 GMC 3500 Dually Duramax
96 Chevy 2500 6.5
05 Yamaha Rhino
04 Gearbox 335FS 5er 14k wet
ib516
Up here!
Posted: 10/07/08 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
Have you read the 2007 HD Shootout? The GM 6.0L gas engine and 6 speed auto did very well stacked up against the gas engines offered by it's competitors. Especially when you consider the Ford V10 powered truck had a 4.30 rear, and the GM 6.0L had a 3.73 rear.
2004 Cougar 301 BHS 6580# Dry, 9000# wet, 9600# GVWR)
2007 Dodge/5.9L Cummins 3500 SRW Megacab 4x4/3.73
Hypertech Max Energy
"MEGACASPER" 10100# GVWR, 5200# FGAWR, 6200# RGAWR
PICTURES
ELIM 3000 Gen (still going)
Collision Reconstructionist
ScanGauge2
Engineer9860
Eagle Scout dad
Posted: 10/07/08 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
-Joe
Ditto.
The 5th wheel tow rating for a 2008 3500HD 6.0L/4.10 ranges from 11,600lbs for a CC/4x4, up to 12,600lbs for a RC/2WD.
And 14,600~16,500 for the DMax.
GM trailer guide 3500HD 5th wheel rating
2002 Chevy 2500HD 4x4 8.1/ZF6sp RC/LB
2001 Chevy 2500HD 4x4 6.0/4L80E EC/SB
1997 Chevy Blazer 4x4
1994 Chevy K-2500 4x4 C6P 5.7/4L80E
1979 Chevy K-30 4x4 4sp 4.10
1977 Chevy K-30 4x4 4sp 4.10 454
30 year student of the Boeing B-17 Flying Fortress
jaycocamprs
Ringgold Georgia
Posted: 10/07/08 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
Payload. If you want a truck to carry the load and not pull it the gas motor is what you want. That D/A combo weight a ton
2004 Silverado 2500HD
2007 JayFlight 28.5 RLS
