ilovewater333
Seaside Oregon
I had the fan belt fixed in my motor and it still squeals. Is that normal? Thank you for your help!
wolfe10
What engine? What belt? Serpentine or "V" belt?
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
pfunk
Shelby Township, MI
serpentine, V, deep V?
year and make helps figure it out, but no it shouldnt squeal, its slipping
2000 Holiday Rambler Endeavor
300 Cat 6spd Ally
jerseyjim
New Jersey
How does one "fix" a fan belt? Adjust it....replace it....but "fix"?
Anyway, a "squeal" usually means: a)too loose b) worn out c) might need a new pully or two d) with extreme wear (real high milage) the alignment (pully(s) moving on shafts) can get out of whack.
G' luck!
bingoldsby
Oregon State Parks - somewhere
Mary,
You really need to give some more details. Did it squeal when you drove away from the place that "fixed" it? Or did it just start doing it again some time after? Are you near the place that worked on it? And if so, can you return it to that place?
Chances are you will need to have someone make the adjustments - if that's what it takes. But my guess is that the tension on that belt was not set properly in the first place.
Good luck from me also. If I was still at Nehalem Bay State Park, I'd come and help you out. I'm at Clyde Holliday near John Day, OR now and won't be back in your area until next month.
P.S. It would have really helped in this case if you would have signed your name - especially with one like "Mary." The resonces would have been more appropriate, I'm sure. Guys are suppose to know this stuff - you know? Plus, I think it's just polite to do so when asking for help.
Brian K7ZRZ
Campgrounding hosting - Oregon State Parks
1987 30' Holiday Rambler Class A
GL1800 Goldwing - Honda Scooter Mounted
2000 Silver Miata LS Toad
Serious WiFi
bill h
el segundo
My wife had a failed serpentine chevy belt replaced at a gas station. They put in a NAPA belt that squealed in a week. Turns out, NAPA has two grades of belt. One made in Mexico and one US. They put in the cheaper Mexican belt, but charged us for the US belt. A US NAPA belt made the problem go away for a coupla years, now.
Bill and Susan
84 Barth 30 tag powered by ht502/Thorley, Gear Vendors OD
Siamese Calvin and Airedale Hobbes
4WD Toyota toad
bldrbuck
Boulder, Colorado
It may be a bad belt but, could be a weak tensioner. There are belt treatments that will help the problem for a while.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
pfunk
Shelby Township, MI
the tensioner on a serpentine system IS a maintenence item BTW
Flyfisherman128
Broadalbin, NY
If it's a V-belt, I have had the pulley on the harmonic balancer rust and cause a squeal. The fix, replace the pulley.
RCL
portola valley, ca
wolfe10 wrote: What engine? What belt? Serpentine or "V" belt?
The lack of response from the original poster seems to be a common thread in many of these "calls for help." Too bad, because the help would be much more appropriate if they either gave more details or had a complete profile which gave the info.
