RV.Net Open Roads Forum: Water pumped out of city inlet when pump on???
 > Water pumped out of city inlet when pump on???
Sinecure
New Orleans
Posted: 10/09/08 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
I noticed in my new-to-me camper that when I turn on the water pump, water pours out of the city water inlet. Is there some sort of check-valve that could possibly be faulty? The only thing I can do to prevent this is screw on one of those caps to keep the pressure contained.
It's a 2007 Wilderness Scout 3102DBS.
2007 Wilderness Scout 3102BDS
2002 Chevrolet Silverado 1500 Z71
SidKaye
Mt Dora Florida, Montreal QC for the Summer
Posted: 10/09/08 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, there IS a check valve in the city water inlet. Sometimes some grit can cause it to stick. You can try gently poking in it. If necessary it is not usually a big job.
Sidney
2003 Dodge Ram 3500 SLT,48RE, 4:10,Cummins HO Diesel,Quad Cab,LWB,SRW,PacBrake,Prodigy, X-Monitor Gauges,Line-X,Bedsaver
2002 Excel,Ltd,30RGW,Hughes Autoformer,Honda Eu1000i, Hughes Direcway HN7000S, Satmex5,
http://www.kayepics.com
Bobbo
Memphis, TN
Posted: 10/09/08 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
It is also cheap and easy to replace if necessary.
Bobbo, Linda and the furry kid (German Shepherd)
'07 Winnebago Outlook 31C on a Ford E450 Super Duty Chassis
NRA Life Member
Near N35 12 17 W89 50 57
USAFBILL
Alabama
And sometimes it is destroyed and has to be replaced. Or put a regular hose cap on it and not worry about.
rocknrun
NC
Posted: 10/09/08 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
Here's some more info that might help:
City Water Inlet Repair Thread
1995 Thor Residency 35 foot
2004 VW Beetle Convertible
Amateur Radio Operator W4KTL
1 Travel Nurse Wife
1 Super Chihuahua, "Taco"
W4KTL's Radio Waves And Radio Days
Rangerdave
Austin Texas
Posted: 10/10/08 03:41am Link  |  Quote  |  Print  |  Notify Moderator
be carefull if you poke at it and theres the screen.
2002 Gulf Stream Ultra Supreme-Demco Kaddy SS Toader Camry
2 peeps 2 poops and lots bbq!
No Fuss Flush
Before you give someone a piece of your mind, be sure you can do with what you will have left.
DznyFan
Lorton, VA
Posted: 10/10/08 11:46am Link  |  Quote  |  Print  |  Notify Moderator
Most likely the O-ring has been dislodged. Very common if folks push in on the plunger when winterizing when the line is uder pressure. I, like many others, have taken a pink shower. I followed the directions on the City Water Inlet Repair Thread and it was very helpful.
2006 Fleetwood Wilderness 3102BDS
2004 Excursion XLT 4x4 V10 4.30
Ride-Rite Air Bags | Air Lift SureSet
Hensley Arrow | Prodigy
Honda EU2000i Gennies
Garmin nüvi 350 | ScanGaugeII
_________________________________________
Me, the Wife & the Kid
Ottawa Campers
Ottawa, Ontario, Canada
Posted: 10/10/08 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
It could be that either the valve was damaged when it was winterized, or it wasn't winterized and it was damaged when it froze. I think it's probably faster and easier to replace the entire city water connection, than to try to fix or replace the o-ring in the check valve.
Good luck
2006 Grand Surveyor 240BH
2004 GMC Sierra 2500HD 4X4 CC LB 6.0litre 4.10 gears
18K Reese/Hidden Hitch Signature Series Hitch
Prodigy Brake Controller
