RV.Net Open Roads Forum: Towing: Geo Tracker towable?
Search only in Towing
Open Roads Forum  >  Towing
 > Geo Tracker towable?
boatbum01
Seabrook, Tx.
Posted: 10/10/08 06:21am Link  |  Print  |  Notify Moderator
Does anyone have information on a Geo Tracker stick shift as to whether it is towable 4 down?
Admiral
Upstate Ohio
Posted: 10/10/08 07:05am Link  |  Print  |  Notify Moderator
I had a 98 a few years ago. Yes, they are as long as they're 4WD. Transfer case in N and standard transmission in 2. Ignition key turned to acc. to unlock steering then you can remove the key if you want. Read the owner's manual before buying any car to tow.
I found the Tracker very easy to tow but very uncomfortable to drive or ride in for more than an hour or so without loosening your teeth and wearing ear plugs. It's fun at first with the "baby Jeep" image but it gets old real quick. I found replacement parts to be extremely expensive...
ex: Throttle position sensor on a Corvette: $50.00. Same part on a GEO Tracker: $400.00. JMHO
2004 Damon Daybreak 2960F V-10
05 Honda Element LX
Only sheep need a shepherd
RRUGG
Newaygo, MI,USA
Posted: 10/10/08 07:08am Link  |  Print  |  Notify Moderator
We had a 92 Tracker with stick shift. It is towable 4 down. The owner's manual specified transmission in 2nd gear, transfer case in neutral, and stop every 200 miles to run the engine for a couple of minutes to circulate the transmission fluid. Then it was good for another 200 miles. Kinda sounds like a pain but it wasn't because we had potty stops, get a drink stop, or just take a break stop. Towed it thousands of miles without incident.
RRUGG
2008 Dodge 2500 QC 4x4 SB Cummins 6 speed auto 3.73
1997 Holiday Rambler 29FK travel trailer
2006 Summit 22RB travel trailer
2003 Dodge Grand Caravan Sport
Bob & Grace professional retirees
Good Sam life members
Camped in 49 states. Missing Hawaii.
Bumpyroad
Virginia
Posted: 10/10/08 07:44am Link  |  Print  |  Notify Moderator
Yep, lots of folks whine about starting it every 200 miles. that is at least 3 1/2 -4 hours for me and I want a stop then anyhow. In fact my wife whines when I go out and start it every 100 miles or less. So I try to stop and do it really often.
bumpy
BarneyS
S.E. Lower Michigan
Posted: 10/10/08 08:10am Link  |  Print  |  Notify Moderator
Please do not double post. See the replies to your question here.
Barney
