RV.Net Open Roads Forum: Class A Motorhomes: Spelendide help please!
 > Spelendide help please!
FrankReno
Reno, NV
Posted: 10/10/08 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Winterized the coach tonight. With power to the coach we could'nt get the washer to spin and pump the pink stuff. Tried a lot of different spin settings. The door lock light does not come on and it will not run.
Your thoughts?
Thanks as always
Frank & Marion
2004 Southwind 36B
Workhorse W22
Little Green Jeep Toad
Driver Jake The Wonder Dog
Copilot Chip the Pup
captainmarvey
Arkansas
Posted: 10/10/08 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
My first reaction would be to check to see if you have a GFI outlet that has been tripped and needs to be reset.
jtfcons
Washington State (The dry side)
Posted: 10/10/08 09:31pm Link  |  Quote  |  Print  |  Notify Moderator
I just finished winterizing yesterday, and if the washer/dryer worked fine previously, then you find the breaker in the electrical panel for the washer/dryer and switch it off. Wait 30 seconds and turn back on. Start the cycle at the beginning to insure the door lock latches. If it does, then advance the dial to just before the last spin setting and then wait for it to advance to the spin cycle. There is a bit of a time delay, maybe 10-15 seconds, between setting the dial and the action taking place, so be patient. This is the scheme I've used and if something did not work the first time, turning the breaker off then on again reset stuff. Good Luck.
John & Sharon, 2 Daughters, 2 Sons-in-law, 5 GK
Scottish Terriers (Bonnie & Chloe)
1997 HR Imp., 38CDS, 1 Slide
325 Cummins C8.3Mech., MD3060, EBw/Cst.Sw.,
Toad-98Tracker 4X4 or 03GMC Envoy 4X4, Excallibar TB, Pressure Pro TPMS, Henderson Mot. Ctrl. Units
bsprague
Milton, WA
Posted: 10/10/08 10:09pm Link  |  Quote  |  Print  |  Notify Moderator
Splendide Instructions
This link will take you to the winterization instructions.
Bill Sprague
2004 Beaver Monterey, 8.3 ISC 350 Cummins
2007 Ford Edge AWD
9 ft Quicksilver inflatable boat w/ 15 hp Suzuki
wagonmaster2
northcentral oklahoma
Posted: 10/10/08 11:39pm Link  |  Quote  |  Print  |  Notify Moderator
Be sure you do it all on Hot setting, then repeat on Cold setting - or vice versa. The original instructions with my 2004 said to set the water temp on Warm and only do it once. Wrong. The next summer I had a water leak when doing a wash load. Called Splendid and they said "Oh Oh our original instructions were wrong". Since there was no hot water in the water heater it only pumped anti-freeze thru the cold side and left water setting in the hot side which then froze and broke the plastic water distributor. Since then have winterized 3 times with no problems.
Wagonmaster2
FrankReno
Reno, NV
Posted: 10/11/08 11:05am Link  |  Quote  |  Print  |  Notify Moderator
As always thank you all!
bobtucker
Dillsboro, IN
Posted: 10/11/08 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have a switch that shifts from the microwave to Washer/Dryer. I sometimes forget to switch it when I've been doing wash and then want to use the microwave.
Bob
FrankReno
Reno, NV
Posted: 10/13/08 11:27am Link  |  Quote  |  Print  |  Notify Moderator
bobtucker
Said it all, thanks!
