RV.Net Open Roads Forum: Class A Motorhomes: DVR Receivers
 > DVR Receivers
FeeLine
Middletown, NJ USA
Posted: 10/14/08 08:51pm Link  |  Print  |  Notify Moderator
Anyone use a DVR in their coach. I am looking for a unit that will stand up to the rigors of traveling in a motorhome. I have been told that the receivers that are commonly used in the home don't stand up well to the bouncing they get when traveling.
We have DirecTV so I would be looking for something that is compatible with DirecTV.
Paul & Ellen with Daphne & Digby 2006 HR Ambassador 40 PLQ, 2004 Jeep Liberty. F.M.C.A. F241322
Good Sam
MRUSA
Wellington, FL
Posted: 10/14/08 09:10pm Link  |  Print  |  Notify Moderator
I have a Samsung Direct Tivo box that has been traveling with me for 4 years without a problem. I did have problems with the previous Tivo when I traveled with it on, using my in-motion disk. The hard drive would not stand up to that punishment. But if you travel with the unit unpowered, the drive heads are parked and I have had no problems.
Marc, Wellington FL
2013 Entegra Anthem 44SL
2018 Lincoln MKX toad
EEZ-RV tire pressure monitor
treecounter
Bend, OR. USA
Posted: 10/14/08 09:13pm Link  |  Print  |  Notify Moderator
WE also have Direct TV. We have had a DVR in it for a year and it works great. We didn't have one in the house but when we got home this spring the DW insisted we get one for the house also. You will need a dual LNB and a device to fix it so you can also have another receiver for a second TV. So you can watch different programing. Your installer will set you up or you can DIY I did. It's not rocket science.
Treecounter
mpmeisch
Arlington, TN formally Aurora, IL
I've run both the HR10-250 and the HR20-700 from Directv in my motor home with no problems. These two units are great because they also have an OTA tuner to receive the locals built in them, so it eliminates the need to upgrade to the digital converter box in February to use your antenna.
Flying for work, cruisin' for fun!
2001 Itasca Suncruiser
Vacation Bound
Palm Harbor, FL
Posted: 10/15/08 04:26am Link  |  Print  |  Notify Moderator
We have a DirecTV HD DVR in our MH. When the Tech. installed our dish, he told us some people had problems with the durability of the DVR's. We take ours out and lay it on the bed. Maybe not necessary but so far so good. We have traveled across country this way.
Annie & Ginger, spoiled Springer Spaniels
Marv Hoag
Redding, CA
Posted: 10/15/08 05:27am Link  |  Print  |  Notify Moderator
I have my DVR switched so I can turn it totally off. Hard drive spinning and going down the road can take a toal. Unplug it!
2000 Monaco Windsor 40
2009 Honda Fit Sport
2012 Chevrolet Equinox
Carvin Marvin
Livingston, Texas, USA
Posted: 10/15/08 07:36am Link  |  Print  |  Notify Moderator
Two years with a direct dvr in upper front cabinet no problems except over heating when the temp gets above 100. Not much insulation in the front clip. I extended the a/c duct so the tv and the dvr are cooled.
Techie
Pahrump, NV, USA
Posted: 10/15/08 08:05am Link  |  Print  |  Notify Moderator
We have a DirecTV HR20-700 DVR with in-motion that we leave on all of the time. Only problem we had was overheating which we solved by adding an exhaust fan to the cabinet where the DVR is located. Also, while recording during in-motion you wil occasionally lose the signal depending upon the terrain (tunnels, overhanging trees).
2011 Airstream Classic Limited 34'
2011 GMC Sierra 2500HD Duramax/Allison SRW
Follow our adventures
bsprague
Milton, WA
Posted: 10/15/08 08:36am Link  |  Print  |  Notify Moderator
I have an R15 from DirecTV. It works fine. Turning it off does not cage the hard disk, so I have it connected to a power strip that I turn off for travel.
Bill Sprague
2004 Beaver Monterey, 8.3 ISC 350 Cummins
2007 Ford Edge AWD
9 ft Quicksilver inflatable boat w/ 15 hp Suzuki
pkunk
Questa, NM
Posted: 10/15/08 10:39am Link  |  Print  |  Notify Moderator
I take our home Direct TV DVR with a bunch of recorded shows with us when we travel. Never had a problem but it is off while traveling.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
 > DVR Receivers
