RV.Net Open Roads Forum: Class A Motorhomes: 2 Bedroom/Bunk house
 > 2 Bedroom/Bunk house
NuttyTexans
Livingston, Tx
Posted: 10/28/08 11:24am Link  |  Print  |  Notify Moderator
Currently have a 5er with a bunk house that will sleep one adult. Looking for something along the same lines in a class A. Anyone ever seen or know of such a thing? No luck looking in the past blogs. Many thanks.
This is in addition to the standard master bedoom...
Ed
driveby
Vancouver BC Canada
Posted: 10/28/08 11:42am Link  |  Print  |  Notify Moderator
Almost every brand has a bunk version now. Mine happens to be an Itasca 35J which is a gas chassis but a higher end version. There are both DP and gas chassis versions now. A regular size adult would fit in my bunks but there are larger ones out there too.
2008 Itasca Sunova 35J Class A
1997 TJ Sahara, hard and soft tops and AC
Held together via Roadmaster Falcon 2 tow bar and stopped by US Gear Unified Brake system.
SooperDaddy
Posted: 10/28/08 11:45am Link  |  Print  |  Notify Moderator
2009 Fleetwood Discovery has a seperate 2nd bunkhouse bedroom. Thats all I could find!
Jayco has a couple of 5er models (if you want to stay with a 5th wheel!) Eagle Lite 5ers with bunks that are twin size, rear queen bed and upper bedroom bunks, and the Eagle has a 5er with a queen rear and an seperate upper bunk room with a twin bunk and a convertable double bed sofa.
Eagle Here!
Eagle SuperLite
My posts shouldn't be taken for factual data, and are purely fictional, for entertainment purposes, should not be constituted as related to scientific, technical, engineering, legal, religious, spiritual, or practical advice. After all it's FREE! Amen. ">
1492
Washington, DC
Posted: 10/28/08 11:46am Link  |  Print  |  Notify Moderator
A few manufacturers use to have them. National RV Surf Side 34E had a master bedroom with a separate room bunkhouse. Newmar also used to have a floorplans with a separate rear room bunkhouse.
You could use the Newmar Canyon Star 3920 toyhauler, which has a master bedroom and a separate garage with bed. It also has a separate exterior entrance door for the garage.
awsmom8
Just Outside Sedona, AZ
Posted: 10/28/08 12:02pm Link  |  Print  |  Notify Moderator
I too wanted a class A bunk house but ended up buying a Class C that has 4 bunks and I use the queen sleeper over the cab. It sleeps 10 as the dinette and couch fold out too. Not that I would ever want to sleep 10... But it is nice as the rear bunkhouse has a door that can be shut when the kids get a bit much!
"> Women who obey the rules don't have any fun! ">
1998 Class C Jamboree 29' Bunkhouse KidHauler 30,000 miles
1998 Saturn SW with 40,000 miles
1993 & 1995 year kids
My Best Friend Frosty-Chi/jack Russel Mix
My Other Best Friend Garmin 330
sedonananny.com
sccawildcat
chambersburg, pa
Posted: 10/28/08 12:56pm Link  |  Print  |  Notify Moderator
If you do a forum search you will find many topics where your question is answered.
NuttyTexans
Livingston, Tx
Posted: 10/30/08 06:25pm Link  |  Print  |  Notify Moderator
Thanks for the feedback. Didn't know there were that many choices. Time for more in-depth research.
michelb
Ottawa, ON, Canada
Posted: 11/03/08 10:43am Link  |  Print  |  Notify Moderator
If you just want a bunkbed, as mentioned there are quite a few of them but pretty much all of them are simply 'a bunkbed in the hallway'. If you want an actual 2nd room, there are not many options.
As far as I know, there's really only the 2009 Winnebago Destination 39N left (http://www.winnebagoind.com/products/winnebago/2009/destination/floorplans.php). Gulfstream had a Crescendo 40UL but it's not listed on their website anymore so might not be produced anymore. National RV has gone out of business so that 34E shown above would only be available as old stock or used. Newmar used to have a loft model 3950/3951 which had a queen at the back (like most class As) but the ceiling was lower and there was a loft above with 2 twins. They replaced it this year with the 4159 (http://newmarcorp.com/uploads/floorplanpdfs/allstar/NewmarAllStar4159.pdf) but according to some that have looked at it, there just isn't enough clearance in the loft to be usable. (The old design (3950/3951) appears to have been much more functional).
Another option could be to take a toyhauler like the Newmar AllStar 4257 (http://newmarcorp.com/uploads/floorplanpdfs/allstar/NewmarAllStar4257.pdf) or the Gulfstream BountyHunter (http://www.gulfstreamcoach.com/products/bounty-hunter/381b.htm) and make a room in the garage (I actually think that something like the BountyHunter could work very well - not sure why other manufacturers (i.e. Newmar with the 4159) didn't go that route with the 'elevated roofline' to create more usable height at the back (I really think that an extra foot height on the Newmar 4159 would have made a huge difference) (note that I've never actually seen the BountyHunter so it's possible that it suffers the same 'loft height issues' as the 4159 but I think 'elevated roofline' is the way to go).
* This post was edited 11/03/08 10:52am by michelb *
