ehouk
Roamin', WY
I know there's a list here somewhere but when I search nothing comes up. Suggestions?
-Ed
2002 Chevy HD3500 Vortec 8100 LS Extended Cab Allison Series 1000 4.10 Rear
GVWR 11,400, GCWR 22,000
2001 Holiday Rambler Presidential 30SCD GVWR 12,500 Actual 11,500
CVW 19000+ --> weight on loaded/hitched truck 10,400
My web pages
More photos
TMBLSN
Washington State
You should search for 'four down', no 'flat footed'.
2006 Jayco 275BHS
1998 C2500
Lee
rv2go
Fulltime between Knoxville, TN and the coast.
Good Sam RV Club
Motor Home Magazine has Dingy guides from 2002 to present. For older than that you will have to rely on the forum.
Winnebago Journey
TN Lic. RV 2 GO
1995 2dr. Hard Top Geo Tracker
www.rv2go.us
I'm here #4335
Travel Photos
bsinmich
Holland, MI
Good Sam RV Club
Go to Remco Towing. They have a spot in the center of their home page that gives a listing of the cars with their engine/transmission combos and can tell what you will need to tow.
2003 Newmar Mountain Aire, Workhorse W22, & 2002 PT Cruiser w/Remco lube pump, Falcon 5250, & US Gear Unified Tow Brake
driveby
Vancouver BC Canada
but isn't Remco out of business? I thought I read that.
2008 Itasca Sunova 35J Class A
1997 TJ Sahara, hard and soft tops and AC
Held together via Roadmaster Falcon 2 tow bar and stopped by US Gear Unified Brake system.
JohnnyT
Goshen New York
Good Sam RV Club
Moved from class A forum
Xpltivdletd
WV, U.S.A.
Might want to pay close attention to details, like how long or how far you can tow a vehicle you were considering. DW and I looked at a few (sorry--I don't recall which ones) prospects, we were told some sort of "yes-but..." about towing; "yes-but" every 200 miles we recommend starting it & idling in D for a few minutes--that sort of thing.
I've read plenty of "assurances" that nobody ever drives far enough, nonstop, yada-yada-yada, don't worry about it. If I had confidence in that, I would not be offering any contribution here. The only SURE thing once you're out on the road is that you only know what you're driving-into, as far ahead of yourself as you can actually see. How far past that--might you be inspired to keep rolling as best you can, maybe more than 4 hours/200 miles, REALLY not wanting much to pull over & stop to nursemaid a too-frail Toad? What are the chances anything you can imagine--would put you in such a fix? OK, how many times would it need to happen?
Our little '95 Tracker has no such limit on how far it can be towed 4-down. I'd thought that defined a suitable vehicle for a Toad; like being pregnant, either one IS or one ISN'T. Then I met these dealers who wanted to make a sale, and THEY wanted the language to become a bit more flexible. I suspect they haven't given up.
wny_pat
Western NYS
driveby wrote: but isn't Remco out of business? I thought I read that. Don't think so.
http://www.remcotowing.com/
Bumpyroad
Virginia
Xpltivdletd wrote: snip
Our little '95 Tracker has no such limit on how far it can be towed 4-down. .
mine of that vintage DID require starting every 200 miles. didn't bother me a bit. I want to stop more often than that anyhow. In fact I used to annoy the wife by starting it every 50-100 miles.
don't let that sway your decision IMHO if that is required by the toad you desire.
bumpy
jeffnkelly
Frazee
Ford Edge... No fuses, not muss no fuss. Just hook it up, Netural, Towing lights and go... Some Saturns need a fuse pulled.
WE really like the way the Ford Edge tows...
My $.02...
YMMV
Smooth Roads!!!
2006 Damon Challenger 372F Triton V10
2007 Ford Edge
JeffnKelly
St. Louis MO
