RV.Net Open Roads Forum: Fifth-Wheels: Gas Shocks for basement door?
 > Gas Shocks for basement door?
thedoghouse
Tennessee
Posted: 11/06/08 09:00am Link  |  Print  |  Notify Moderator
Anybody know where to buy a complete kit? Brackets shocks etc?
2008 Holiday Rambler Presidential Suite 36 RLT
2011 Ford F350 CC DRW B&W Companion
lv2rom
Kansas City, Missouri
Posted: 11/06/08 09:12am Link  |  Print  |  Notify Moderator
Google on RV Gas Struts.....it should say on the ones that you have what the pressure load is.....Brian
2005 F350 Dually -AFE air box/MRSP exhaust/Bags/Bilsteins/Energy Susp./Michleins
2002 Hitchhiker Fiver 29.5 RLBG - Moryde Pin/Gas shocks/Michelin XPS Ribs/Full solar
admiral0647
Illinois
Posted: 11/06/08 10:04am Link  |  Print  |  Notify Moderator
This hardware company KenCon sells to the RV industry and the public.
When you get to their web site look at the "BRACKETS" and "GAS STRUTS" categories.
good luck...
Jim
I started with nothing... and have most of it left.
Damon Challenger 377c
Toyota Yaris Dingy
Scottish Terrier
cummins2014
Utah
Posted: 11/06/08 10:46am Link  |  Print  |  Notify Moderator
I have to ask why do you need shocks on the basement door, does it not latch in the open posistion ????
lv2rom
Posted: 11/06/08 12:06pm Link  |  Print  |  Notify Moderator
FYI...many RV's use pressure struts on compartment doors instead of going all the way up to a latch clip...Brian
rockintom
Livingston, TX
Posted: 11/06/08 02:02pm Link  |  Print  |  Notify Moderator
I was told from my manufacturer that for a successful installation of gas struts on the compartment doors, that upgraded doors have to be also installed. The upgraded doors have the reinforced area to support the strut mounting. The struts mounted in the old doors will pull loose in short order. Two doors and struts were about $500 retail....I'll pass for now and get them on my new rig. rockintom
Rockintom
'12 Excel Limited GKE 33 ft., trailer named "Charm"
'14 1 ton Chevy DRW D/A Reese 20K hitch Fold-A-Cover bedcover - truck named "Bullet" Fulltiming since 2005
NC Hauler
Pence Springs WV
Posted: 11/06/08 02:47pm Link  |  Print  |  Notify Moderator
rockintom may be right, sig 5er came with the basement doors that have the gas shocks and these doors are heavier then the ones on any 5er or TT that I've owned in the past. They're fairly handy, though you wait for them to travel up at their own speed and they open far enough for you to do anything you need to, but believe I may have liked the "regular" type opening doors better, I opened the door faster, locked it into place and it was completely out of the way. If the shocks were to "go bad", believe I'd take them off and mount the
"regular type" locking device and remove the shocks completely. I purchased sig. 5er "off the lot", if I had ordered one, would have liked the heavier door due to insulation factor, but probably would not have ordered the shocks...not a deal breaker one way or the other to me.
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
wittmeba
Virginia
Posted: 11/06/08 03:18pm Link  |  Print  |  Notify Moderator
I did this - used magnetic door stops on our main door. I will do a couple of our storage doors too - the ones I use most.
http://members.cox.net/bruce.wittmeier/images/MagDoorProp003.jpg
http://members.cox.net/bruce.wittmeier/images/MagDoorPropMag.jpg
Probably use something like this on the hatches - not as likely to hit or bump.
http://gatelatchusa.com/door_stops.html
Magnetic Door stops
Lots of choices.
And believe me they have plenty of strength to hold even in winds. We can still use the std if we want the door open during high winds too. One indicated it would hold 13#. Thats like 2 gallon jugs of milk.
NRA Member & supporter of the 2nd amendment - over 5,000,000 strong
Firefox® 33
Log home images - Updated 05/19/2013
cummins2014
Utah
Posted: 11/06/08 08:27pm Link  |  Print  |  Notify Moderator
Not to argue, but whats the sense ??? I lift the lid, latch it ,do my thing,and close it. I am all for upgrades, but this one escapes me. I want the door up all the way and out of the road. I don't want it part way up or almost up and have me or someone else run into it. I am always looking to make my 5ver more user friendly, but like I said this one is way over my head as to the need Maybe I missed something here????
NC Hauler
Pence Springs WV
Posted: 11/06/08 10:39pm Link  |  Print  |  Notify Moderator
Actually, at least on my unit, when the basement door is open, the door is so far open you would have to go out of your way to walk into it. I bought my unit "off the lot", and it had the gas strut actuated basement doors on it, thus, I have them. If I had a choice, as others mentioned, I probably wouldn't have them. I see no real advantage to them.
