hotrod4x5
Southern Calif
Good Sam RV Club
bankcardrep1 wrote: We were in Chattanooga this past week. Plenty of DTV. We have a Digital TV. Tuned to DTV Channel. It said Low Signal Strength and produced a crisp black screen. I keep hearing everyone say that the antenna is not important...but, maybe there is an amplifier or distribution system that is not passing the signal???there is a little green light where we plug the coax in the wall with an on off switch...no signal either way.
Rig is 06 Dutchman so it ought to be up to spec??? Did you try turning the antenna and rescanning? My batwing only works in a couple or orientations. Any other and I get nothing.
Rodney 2005 Laredo 29GS 2002 F250 V-10 Hughesnet Satellite Internet
SCVJeff
Santa Clarita, CA.
Whoever everyone is, they are wrong. The antenna is absolutely the most important piece of producing a usable picture. If you cannot recover a signal there is little chance of making a picture.
Hotrod: The batwing is directional on UHF off the front of the antenna
Jeff - WA6EQU
hotrod4x5
Southern Calif
Good Sam RV Club
SCVJeff wrote: Whoever everyone is, they are wrong. The antenna is absolutely the most important piece of producing a usable picture. If you cannot recover a signal there is little chance of making a picture.
Hotrod: The batwing is directional on UHF off the front of the antenna What is considered the front?
ronfisherman
SE Michigan
Good Sam RV Club
The side opposite the arm that raises and lowers antenna.
Here is a link to Winegard's Wingman. Shows a picture of the Wingman mounted. That side is front of antenna.
hotrod4x5
Southern Calif
Good Sam RV Club
That's interesting. Currently my standard wingman works best with the blade pointed toward the broadcast antennas.
edbehnke
Northern Michigan
Good Sam RV Club
for tazmangk..take a look
http://www.12volt-travel.com/index.php?main_page=page&id=5
eddie and sandie
roscommon, michigan
2000 31ft. Terry 5th wheel
winter in mexico
navybanker
West Tennessee
Not to steal the post, but some say hooking up TV to converter box to antenna with power boost on will burn up the converter box. Some say no it won't. Which is it??? I have hooked up this way and have clear pictures from several stations at least 60 miles away. Concerned leaving the converter box on and hooked up to power will ruin the converter box.
SCVJeff
Santa Clarita, CA.
hotrod4x5 wrote: That's interesting. Currently my standard wingman works best with the blade pointed toward the broadcast antennas. The "front" of the antenna is the smallest element on the Wingman.
craneman120
home
Good Sam RV Club
so let me get this stright,right now I have the cable from the RV's antenna,going to the new converta box,then from the converta box ,back to the RV'S amp to feed both tv's..and they both work..So I'am OK???? Craneman 120
edited 07/12/09 06:05pm by craneman120 *
reachrob
Bozeman, MT
Born2RV wrote: Thanks for clairfying this matter. I noted on the first page the sequence of installation is antenna distribution box converter tv and there is a temptation to hook the converter box directly to the antenna but that is bad. If I do not have a distribtion box, wouldn't I have to do that?
Also, I understand now that it is the TV not the atenna that determines if a converter box is needed. I was going to ask if they make a batwing that will receive the digital signal but it doesn't matter if my TV won't receive it. Thanks !!
I too have no "distribution box". Can anyone answer the question of how to hook up a coverter without a distribution box??
2009 Jayco Jay Feather Sport 218
2000 GMC Sierra 1500 5.3L
McKesh Mirrors
