gourmet
California
Good Sam RV Club
I am planing towing a camper trailer or a 5th wheel with my 5.7L Tundra and wonder if anyone has had experience doing this. Obviously it will be a smallish trailer, max unladen around 8000lbs. I will be traveling for the next couple of years and hope to see most of the country including Alaska. I live in Hawaii at the moment. I could do with any advice you may have.
crickeydog
Marietta, Ga.
gourmet wrote: I could do with any advice you may have.
IMHO: Ya need more truck! Good luck.
Happy camping!!! See ya'll down the road!!!
USAF RETIRED
2006 GMC 3500 CC DRW D/A 4X4 SLT,PREDATOR,VOLANT CAI,FS2500 OIL FILTER'S
2004 HR PRESIDENTIAL 30 SCD.
CHEROKEE & CHEYENNE MINI DOXIE'S. WE'RE IN CHARGE!!
LOADED LIKE A FREIGHT TRAIN, FLYIN LIKE A JET PLANE.
IT'S 5 O'CLOCK SOMEWHERE!!
azBuckeye
Cave Creek, AZ
I love the truck. Pulls my trailer very well through the northern Arizona Mountains. I tend to tow between 60 and 65 mph and get between 8 to 10 mpg. My biggest complaint about the truck...small gas tank. You may need to carry extra fuel if planning very remote journeys.
2008 Jayco JayFlight G2 29FBS
2007 Tundra - 5.7, 4.30 gears, SR5, CrewMax
jboyer
Wintering (living?) in Mexico
Good Sam RV Club
Good travels. We have a 5.7 L Tundra 2007 with over 40000 miles, pulling a 29 foot Cougar; about 9000 pounds. Great TV!
Enjoy
kmfvfr
Las Vegas
Good Sam RV Club
I would get a bigger truck if the weight will be 8K LBS unloaded. Too many variables there...hills, wind, trailer weight, length, all that sort of stuff. I tow maybe 6,500 lbs max loaded on occasion and unless the hills or wind did not exist, then ya..the Tundra doesn't even know it's back there. But for the few times I have been in some windy weather, I would want a bigger truck. Don't get me wrong, it was OK in those conditions, but just that...OK. 8K LBS or more would be too much IMO.
2008 Pacific Coachworks Tango 276 RBS
2007 Toyota Tundra TRD 5.7L
Prodigy Brake Controller
Yamaha EF2400iS Generator
Yamaha FJR1300
skipnchar
Topeka Kansas USA
The Tundra (depending on the year and model) can be a very good tow vehicle for a travel trailer but not NEAR enough payload for a 5th wheel with a UVW of 8,000 lb. As a matter of fact if you have a UVW ofl 8,000 lb. you probably ALSO have too much travel trailer since any weight of passengers, cargo or optional equipment on the truck will reduce the tow rating and must be compensated for. If you tow a 9,000 lb. (loaded weight and that is loaded very lightly) 5th wheel you are looking at a pin weight of over 2,000 lb. and that ALONE is more than your trucks payload capacity. Look for a MUCH smaller 5th wheel and be CAUTIOUS about tongue weight for a travel trailer of that size as they can also put you over your payload capacity. Good luck / Skip
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
priestlake
Spokane, Washington
I have a 5.7 2008 4 wheel drive. You are very limited in towing a fifth wheel due to the pin weight. If you are looking at a full size fifth wheel you need at least a 2500 and probably a deisel. An 8000 lb trailer is pushing it but you truck should tow 10,300. Good luck
LAdams
Northern Illinois
Good Sam RV Club
#8000 unladen is hardly a smallish size trailer... And towing a 5er, especially of that size, will surely overload your truck on GVWR and most likely rear axle rating as well...
If your going for that size 5er, your gonna need a larger truck... If it's a conventional TT you'll be creeping up on, if not exceeding, the GVWR and possibly GCWR of your tow vehicle...
Run your number s very carefully if your thinking of a TT of that size and weight...
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
amxpress
Clayton, NC
Good Sam RV Club
What do you mean by "max" unladen?
What is the GVWR of the TT you're interested in?
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2008 Palamino Sabre 31RKTS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
Travel in peace, left the M-I-L at the zoo with her relatives...
harper223
West Texas
We tow a 7800 pound Jayflight G2. With the weight distributed evenly and I try to keep the total weight of the TT with all our stuff under 9000 pounds. How do I know this? I weighed it. Tows like a champ. No problems. Just make sure your weight is distributed nice and even all up and down your rig.
